100 Series T/D 2003 Low oil pressure
Submitted: Wednesday, Dec 05, 2007 at 22:44
ThreadID: 52284 Views:2386 Replies:3 FollowUps:3
Just checking with other owners where their oil pressure is at idle and run. Mine hardly moves which is at quater most of the time.
On long trips it might jump up to half for a short period but usually sits at quater.
Any ideas on issue if one?
Reply By: 96 GXL 80 series - Thursday, Dec 06, 2007 at 00:01
I am sure that someone else started a thread about this awhile back.
I think it came down to a faulty sender unit.
AnswerID: 275218
Follow Up By: Brooka27 - Thursday, Dec 06, 2007 at 00:13
Thanks mate as you mentioned I have found a previous thread with some detail.
Cheers Brooksy.
FollowupID: 538911
Reply By: fisho64 - Thursday, Dec 06, 2007 at 00:19
Yes it was the subject of a service recall by Toyota, they should replace the sender for free if it hasnt been done already.
AnswerID: 275219
Follow Up By: Member - Graham H (QLD) - Thursday, Dec 06, 2007 at 18:50
Could u please post the thread number of it
FollowupID: 539045
Reply By: Member - Graham H (QLD) - Thursday, Dec 06, 2007 at 18:54
Mine is at over 3/4 on a cold start then drops back to just above half when doing 50kph hot and down to about 1/3 at hot idle. Bosses Sahara is about the same his 100,000 mine 70,000
AnswerID: 275312
Follow Up By: Brooka27 - Friday, Dec 07, 2007 at 12:31
I went to the local toyota dealer, common problem for 100 series apparently.
Anyway after some discussion bought a new oil pressure switch sender unit PN# 83520-35031.
$125.00 thanks very much!
Anyways easy to put in 20mins, 14mm open end spanner.
To make it easier, remove the plastic saddle clip from the metal bracket for the wiring harness in front of the unit and dont forget to slide the sensor wire clip off before removing.
You will spill small amount of oil.
Works a treat now.
Good Luck.
FollowupID: 539207
