landcruiser fuel hammer
Submitted: Thursday, Dec 06, 2007 at 19:52
myrv51
new site visitor to site have a problem with 2002 hdj 4.2 diesel rv
would welcome comments re solving annoying noise
Reply By: Member - Graham H (QLD) - Thursday, Dec 06, 2007 at 19:58
A few more specifics would help you get some advice
275324
Reply By: Marn - Thursday, Dec 06, 2007 at 20:00
Turn up the radio, or give a few more clues. What where when
275325
Follow Up By: myrv51 - Thursday, Dec 06, 2007 at 20:22
Sorry mate, When i'm just taking off or when slowing down under revs, sounds like flicking a ruler on the edge of the desk.
Toyota said its a common problem on some ealier models, and they changed it on the later models, they said they fix it with a fuel dampner???
Do you know of this type of problem??
MyRV51
539068
Follow Up By: Member - Jeffrey J M (NSW) - Monday, Dec 10, 2007 at 20:20
I had it in my 79 series, toyota put a dampner in the fuel line, have not had it since, that was 4 yrs ago.
539852
Reply By: 96 GXL 80 series - Thursday, Dec 06, 2007 at 20:01
What is it like: Starving for fuel?
Air in the line?
Running out of fuel?
A bleeding problem?
as in the 1st post a bit more info would help.
275326
Reply By: nowimnumberone - Thursday, Dec 06, 2007 at 20:01
quite a common problem with most 4wds
leave the wife at home
275327
Reply By: Member - 'Lucy' - Thursday, Dec 06, 2007 at 20:17
Even better
TURN IT OFF = no more noise.
275332
Reply By: Member - DOZER- Thursday, Dec 06, 2007 at 20:31
fuel lines are vibrating, dont worry about it, common fault, turn up the radio or buy a new 200, with throw away unserviceable injecters at 1k a piece...and a owners manual that states..."if you think you have got bad fuel, pull over and call Toyota"
275334
Follow Up By: Member - Sweeney (WA) - Thursday, Dec 06, 2007 at 22:26
"fuel lines are vibrating, dont worry about it, common fault"
DOZER
I driven a number of crusiers from 47's to 79's (plus a 60 and a 80), I have not heard of that one before and I have driven some station toyota's too. If that is the case, it should only be loose/missing bolts or rubber somewhere along the fuel lines. Check it anyway as it shouldn't happen.
539115
Follow Up By: Member - Phil G (SA) - Thursday, Dec 06, 2007 at 22:44
Only happens to the 1HD-FTE motors in the 2001-2002 78/79series. For whatever reason, Toyota skimped on the dampeners that they put just upstream of the injector pump on other models.
539121
Follow Up By: Member - Sweeney (WA) - Friday, Dec 07, 2007 at 09:05
So, you're talking about the injector lines themselves? Between injector pump and the injectors.
539163
Follow Up By: Member - Phil G (SA) - Friday, Dec 07, 2007 at 09:23
"you're talking about the injector lines themselves?"
No. Sorry, I may have been confusing with the term "upstream" which I meant to mean back towards the fuel
tank.
The steel fuel pipe that runs along the firewall between the fuel filters and the injector pump is the source of the noise. The vibration is transmitted back from the injector pump. The factory fitted dampener is located on the inlet manifold on the inlet fuel hose.
The noise is most pronounced when you're off throttle and at low speed - get it constantly when 4wding in low range. Sounds a bit like an exhaust brake.
539167
Reply By: Member - Phil G (SA) - Thursday, Dec 06, 2007 at 21:06
Dozer is right again!!
You've got the 78 or 79 series. The noise is caused by vibration being transmitted back from the pump.
From 2003 onwards they fitted a black fuel dampener between the steel fuel line and the injector pump (bolts neatly on the intake manifold). My 2002 model had the same problem as yours, and Toyota fitted the dampener for free.
Before Toyota sorted the problem, the common fix was to replace the steel fuel pipe with a rubber one, but the dampener does the job better.
275347
Reply By: Member - Kiwi Kia - Friday, Dec 07, 2007 at 07:32
To everyone who posted a negative reply !
This IS a
well known problem and has now been
well answered here. If you are wanting some advice sometime in the future I am sure you would not want some of your drivel posted back at you. Nothing wrong with a bit of humour but how about engaging brain before hitting the key board occasionally when a genuine question has been posted.
275424
