Oziexplorer Question - set map feature
Submitted: Thursday, Dec 06, 2007 at 23:00
Ozboc
Ok in oziexplorer ( on my laptop ) i set a Map feature - when i go into properties i name it something like " turon
camping spot" add a photo for visual reminder ( little Blue icon circle with a 12 in it)
NOW is there an easy way to find this map feature , or a search feature that if i then type in Turon
camping spot - it will find it for me and take me to the correct map and then the the correct spot on the map ?
clicked on the name button on the end - but does not find it ....
is there a quick solution rather than scouring the map looking for the map features i have added?
Boc
if pic does not work or is resized smaller try
direct link to pic
Reply By: Member - Doug T (FNQ) - Thursday, Dec 06, 2007 at 23:05
12....??? where
275383
Follow Up By: Ozboc - Thursday, Dec 06, 2007 at 23:07
did you not look at the picture ?????? Its directly under the MAP name
SOFALA (FAL )
539129
Follow Up By: Member - Doug T (FNQ) - Thursday, Dec 06, 2007 at 23:12
Oh ok I thought you meant the one on the end of the green line
ON THE MAP,
539131
Follow Up By: Ozboc - Thursday, Dec 06, 2007 at 23:15
No that would be a WAYPOINT - people who use oziexplorer would know that --
539132
Follow Up By: Member - Doug T (FNQ) - Thursday, Dec 06, 2007 at 23:21
Yeh I suppose they would, I binned my copy about 2 months ago , there's better ones.
539133
Follow Up By: The Explorer - Thursday, Dec 06, 2007 at 23:34
LOL
539136
Reply By: The Explorer - Thursday, Dec 06, 2007 at 23:31
Hello - you can display all map features present on any one map by using VIEW - LIST- MAP FEATURES. You can then click on relevant map feature in the list and then the red bulls eye 'plot location.." icon and you will be taken to that feature. Maybe not the solution you were looking for but the only easy option AFAIK.
If you want to use the name search function to find certain "features" you will need to create a name search file. One method to achieve this is to create wayponts at the same locations as you features and convert this file to a name search file
Read about making name search files here
Get the actual name search program here
Name Search Program
Also it is possible to import map features from one map to another using IMPORT MAP - MAP FEATURS AND COMMENTS FROM MAP FILE. Thisi would enable you to import all your map features from say a series of large scale maps (say 25K scale) to a small scale map (say 250K) so you could search them all at once using the map features list...and then select a better scale map when feature you want is found.
Hope this advice helps
275387
Follow Up By: Ozboc - Thursday, Dec 06, 2007 at 23:48
thanks heaps - works !!!
Boc
539138
