Mobile as a Modem
Submitted: Saturday, Dec 08, 2007 at 15:31
Member - Ian F (WA)
Can any one tell me if, purely on a short term basis, you can you subscribe for a month only basis , ie holidays ? I was thinking of the $89/1GB . I know it is expensive but I am prepared to pay for one month
Thanks in advance
Ian
Reply By: chisel - Saturday, Dec 08, 2007 at 15:46
Yeah, telstra allow you to change your browsing pack each month (or stop altogether). At least they do for the cheaper ones - I assume also for the $89 one as there's nothing on their website to suggest otherwise. Ask them when you ring to
sign up
http://www.telstra.com.au/mobile/plans/browsing_packs.html
275639
Follow Up By: Member - Ian F (WA) - Saturday, Dec 08, 2007 at 16:00
Thanks Chisel for your help
Ian
539402
Follow Up By: Member - Doug T (FNQ) - Saturday, Dec 08, 2007 at 16:25
chisel
That is from a mobile phone only , cost a damn fortune . He probably wants to access EO from a PC or Laptop,
539406
Reply By: Member - Doug T (FNQ) - Saturday, Dec 08, 2007 at 16:17
Ian
I have not seen anywhere where you can just have it for a Month, you will find it will have to be for a 12 month contract , although those little useless CDMA wireless modems if puchased outright at $499 there was no set contract,
275641
Reply By: Member - Christopher P (NSW) - Saturday, Dec 08, 2007 at 16:26
HI Ian F, as far as i know you get charged a data rate if you you use your mobile phone for a modem, depending on which carrier you are with. Telstra will let you use there dial up service via mobile phone or if you want cheap internet get the next g wireless bb as it will work anywhere, either usb or pcmcia card with the litle o bleep y antennea they have as
well for an extra $40 approx! If your with telstra then you can add it onto your bill and pay next month.
275643
Reply By: Member - Doug T (FNQ) - Saturday, Dec 08, 2007 at 16:38
Ian
I just checked your post again , on the re-read I understand now what you mean , useing the Phone as a Modem and I presume to access Bigpond, Yes that can be done if you have a dial up plan , Instead of using the internal Modem that would normally be connected to a phone line you will use the Mobile as an external Modem , If you get a prepaid 1 month dial up from telstra and programm the laptop to use the phone as a modem ....Bobs your Uncle , ....been there, done that, keep your calls/browsing short unless your on a capped plan ie $49 will be about $250 in calls.
275645
Reply By: Member - Ian F (WA) - Saturday, Dec 08, 2007 at 16:54
Thanks to everyone, I forgot to tell you I have a testra next g mobile and have used my mobile as a modem on my laptop as a test . This was using a data pack $8.00/3Mb. It worked
Ian
275648
Follow Up By: George_M - Saturday, Dec 08, 2007 at 18:32
G'day Ian.
Your data pack seems a bit expensive. I'm on a monthly data pack of 20Mb for $10, also using NextG. The trick with Telstra is that they do not let you know when a cheaper deal on data becomes available.
George_M
539435
