Tennis Ball Airbags
Submitted: Saturday, Dec 08, 2007 at 19:26
Rosco - Qld
I heard of a trick today where a bloke got tired of his polyair bags letting go.
So he filled the coils with tennis balls and reckoned they worked a treat.
Anyone else heard of it or given it a go??
Reply By: Willem - Saturday, Dec 08, 2007 at 19:29
Must the onset of silly season
Go for it Rosco!!!....hahahahahahaha
275672
Follow Up By: Member - Roachie (SA) - Saturday, Dec 08, 2007 at 19:55
When I bought the ChevNissan in November last year, it had about 5 tennis balls in each of the front coils......they were all totally stuffed, so I wouldn't place too much faith in them as an alternative for Polyairs. As the previous writer has said, Polyairs will last for donkey's ages if they are looked after and not over-inflated.
539451
Follow Up By: QLD Kev & Darkie - Saturday, Dec 08, 2007 at 20:35
Sounds like "Game, Set, Match" IMO LOL
Kev
| Russell Coight:
539468
Follow Up By: Member - Doug T (FNQ) - Saturday, Dec 08, 2007 at 20:56
Kev
"You Can't be serious"
539480
Follow Up By: QLD Kev & Darkie - Saturday, Dec 08, 2007 at 20:58
What brand were the Tennis balls??
As this could make a great deal of difference to ride
Kev
| Russell Coight:
539482
Follow Up By: Member - Fred G (NSW) - Saturday, Dec 08, 2007 at 21:46
Fair go you clowns. Must be Saturday night fever out there, this bloke wanted some useful advice, and got it in part from some respondants, but not until you clowns respond with nothing useful to add. I guess the villiage clowns can't stand not having an audience.
LOVE ALL.....
539502
Follow Up By: Willem - Saturday, Dec 08, 2007 at 21:57
bleep -off Fred!
539504
Follow Up By: Member - Doug T (FNQ) - Saturday, Dec 08, 2007 at 22:03
Fred
Gawd damn it Fred , Sorry mate, truly sorry , if we all had known it was going to pi$$ you off we wouldna done it ,,.... Sorry , Sorry, Sorry,
539506
Follow Up By: Member - Roachie (SA) - Saturday, Dec 08, 2007 at 22:45
Slazenger......only way to go....
539521
Follow Up By: Smudger - Sunday, Dec 09, 2007 at 10:10
Thank you ballboys.
Thank you linesmen.
539560
Follow Up By: Des Lexic - Monday, Dec 10, 2007 at 10:09
Poor old Fred, he just got Aced. At least it was a no-love loss game.
539743
Reply By: Max - Sydney - Saturday, Dec 08, 2007 at 19:34
Never had to! Have had three sets of Polyairs - in an '88 Jackaroo where they lasted about 90 k (including
Cape York,
Kimberley, Tanami etc), 80 series with lifted
suspension about 200 k, (including around the block,
Kimberley,
Pilbara, Canning,
Corner Country), now a set on lowered
suspension but only done maybe 30 k and towing caravan.
Tennis balls might be the go if one pops, but have never met anyone let down by them.
Max
275675
Follow Up By: Crackles - Saturday, Dec 08, 2007 at 20:26
Similar experience here Max with several hundred thousand KM's of maintenance free driving with Polyairs on 2 vehicles. Only issue I've personally had is damage to the hoses due to an installation error. Those that I've seen or heard had them burst were grossly overloaded and isisted on running them at the maximum rated 30 PSI.
The tennis ball idea has been around since at least the early 80's when I saw them fitted into a Rangie.
Cheers Craig.............
HZJ105
539462
Reply By: Member - Crazy Dog (QLD) - Saturday, Dec 08, 2007 at 21:38
Tennis elbow hurts enough..... but Tennis balls !!!
Hmmm!!!
Grrr!!!
275699
Follow Up By: Gramps (NSW) - Saturday, Dec 08, 2007 at 21:46
Hahahahaha better than the Friday Funnies.
539501
Reply By: Member - Fred G (NSW) - Saturday, Dec 08, 2007 at 21:50
Stop the racquet immediately.
275701
Follow Up By: Member - Doug T (FNQ) - Saturday, Dec 08, 2007 at 22:06
Fred
All them sorry's is Null and Void now
539509
Follow Up By: Member - Fred G (NSW) - Saturday, Dec 08, 2007 at 22:19
Okay mate...that's enough racquet for one night, balls up everyone.
539512
Follow Up By: Member - Roachie (SA) - Saturday, Dec 08, 2007 at 22:47
Looks like you've had your medication Fred....goodonya....... hahaha;-))
539522
Reply By: The Rambler( W.A.) - Saturday, Dec 08, 2007 at 22:58
Iwould not have thought that the max. ratings on Pollyair air bags was only 30psi.In that case Iwould only be using Firestone which can be used up to 100 psi.
275715
Follow Up By: TroopyTracker - Sunday, Dec 09, 2007 at 18:27
Rambler,
You have to compare bellows with bellows(black hour glass shape/for on top of leaves)-not the same as the bags (red/blue-for inside coils).
Reccomend the polyair bellows over the the firestone just on polyairs service/advice.
Matt
539629
Follow Up By: Crackles - Sunday, Dec 09, 2007 at 19:09
Both Polyair & Firestone airbags that fit inside coil springs have a maximum preasure of 30 PSI. They are basically the same just a different color plastic material. As Matt has indicated the airbags that can be pumped up to 100 PSI are of a totaly different construction being a rubber bellows and not at all compatible with coil springs. Maybe this confusion with the maximum inflation is one reason why people do pop them.
539640
Reply By: Member - Bucky (VIC) - Sunday, Dec 09, 2007 at 07:19
Emergency response theory,
well I would give the tennis balls a go ,, but just to get
home so I can replace them.
I have heard of them going bang, but its usually the drivers fault.
Our Poly Air Bags are brilliant, been on almost 2 years, max air I need to put in them is 18 psi, carrying soil and broken bricks. Normally I run just over 5 psi. Never an issue.
Adjustment is made with a bike pump.
Bucky
275739
Reply By: Member - Karl - Sunday, Dec 09, 2007 at 09:39
My Polyairs are going fine after 5 years of use. I have never had to pump them up past 25 psi - that is a fully loaded vehicle towing a camper trailer.
I can't imagine why you would want to be able to pump them up to 100 psi - what sort of load would you be carrying to need to do this???
I can see the tennis balls working as a quick fix in an emergency - assuming that you are carrying them in the first place (along with all your other spares).
Karl
275759
Reply By: PeterInSA - Sunday, Dec 09, 2007 at 15:07
Rosco,
Spoke to a prospector out from
Laverton in WA a few years ago he swore by them "Tennis balls that is" and if you wanted to increase the height just add another ball. More than half his travel was on dirt roads. Howver I don't think he was using the Tballs from big W at $10 for a dozen.
Based on what he said I think anyone critical of this method has not tried it. However I would be wary of one of the Tballs blowing out, affecting your steering causing an accident and you maybe stuck with an Insurance claim whereas if the same thing happened with an airbag you would probably be in the clear.
275785
Reply By: The Rambler( W.A.) - Sunday, Dec 09, 2007 at 23:35
Matt is correct and sorry for the confusion as Iwas referring to the bellows type which is a different configuration to the air bags inside the coils.The firestone bellows have a max. pressure rating of 100psi but I use 40-50psi fully loaded with the camper trailer.Sorry for the mix up but the bellows are frequently referred to as air bags.
275864
Reply By: KSV. - Monday, Dec 10, 2007 at 08:47
Hey, guys, you are laughing for nothing. While I do not believe that tennis balls good enough for big 4WD, they surely good for small sedans. In Russia in 70-s – 80-s plenty of people been using them with great success in Ladas to carry bigger loads. In those times in Russia was impossible to get stiffer springs or polyairs or something.
Serg.
275884
Serg.
275885
Reply By: KSV. - Monday, Dec 10, 2007 at 08:48
Serg.
275886
