Dual battery Isolater capacity
Submitted: Saturday, Dec 08, 2007 at 20:53
kcandco
I am looking into fitting a dual battery system. My alternator is rated at 90 amps. At the risk of sounding foolish, Does this mean I have to fit a 90 amp+ dual battery isolator or would a 80 amp isolator be ok? Also Why?
thanks Kc
Reply By: Member - Jerry C (WA) - Sunday, Dec 09, 2007 at 00:33
Hi kcandco,
Without trying to guess how you want to wire the batteries to operate, I would suggest that you use a "Clohessy" 500 Amp switch or equivalent which will be able to carry the starter motor or winch current without fear of melting the contacts.
Cheers, Jerry.
275732
Reply By: Derek from Affordable Batteries & Radiators - Sunday, Dec 09, 2007 at 01:00
Hi Kc
The Isolator must be rated to what the aux battery or batteries can draw. The most I have ever seen one battery draw is 44 amps. Please advise your battery type and size and we can assist you. Almost any isolator on the market will take care of a 90A alternator.
Derek.
275734
Reply By: Derek from Affordable Batteries & Radiators - Sunday, Dec 09, 2007 at 01:01
Hi Kc
Derek.
275735
Follow Up By: Thylacine - Sunday, Dec 09, 2007 at 02:18
This is true of the charging side only.
If you have a winch, your dual-battery system needs to be able to either cope with this load or be bypassed when the winch is being used. Due to the fact that a lot of people install a second battery specifically to alleviate the load on a single battery when winching, the second option isn't common.
Easiest way around this is to install a marine-service battery switch (battery 1, 2, or both) and have your winch connected via this, with your battery 'isolator' being disconnected when power is available to the winch.
539543
Reply By: yowie - Sunday, Dec 09, 2007 at 11:39
You will also have consider if you wish to start your car off the Aux battery if your main battery dies. I always wire
mine with a manual over ride switch supplied from the Aux battery so i can close the solenoid to start off the Aux battery if the main battery is dead..
275769
Follow Up By: Member - Mainey (wa) - Sunday, Dec 09, 2007 at 13:37
I use a similar system (12cm jumper lead) to charge the Cranking battery when camped for extended periods !
539582
Reply By: Member - Mainey (wa) - Sunday, Dec 09, 2007 at 13:32
Kc,
First question is, are YOU using a winch ?
2nd is; what's your first choice of battery isolator at present that's 80 Amp rated ?
I only ask to get an evaluation of price range, no good suggesting an elcheapo mechanical solenoid when you are prepared to invest in a decent electronic battery isolator for an extra few $$.
Question is;
What will run off the second battery ??
What capacity and type of battery will it be ??
Will the 'load' fully drain the second battery or is there a 'cut-out' device involved to stop fully draining the second battery ??
Hint: all electronic battery isolators (I'm aware of) are
well in excess of the rating of your alternator !!
They are an investment, you remove it and use on the next vehicle.
275781
Reply By: kcandco - Monday, Dec 10, 2007 at 15:11
Thanks everyone for your help!!!
I intend to have a 100AH Agm mounted in the tailgate of a Pajero wagon. I have a 12volt Bushman Fridge in the tailgate, drawing 5 amps and using up to about 40 amp hours in a 24 hr period. There is no winch or other accessories. I would probably drive every day but at worse case scenario would probably draw 80 - 90 amps from the auxiliary battery before recharging. I also have a Supercharge Gold battery 950cca and 200 minutes RA fitted to my camper but if necessary could use an andersen plug to charge one or the other (not together??) as the camper battery does not normally get much use (led/fluoro lights and waterpump). The battery isolator I have seen is a Sidewinder BI-80. I have also considered a Redarc which I can buy of the web for $95 + postage. Any other suggestions welcome.
275938
Follow Up By: Derek from Affordable Batteries & Radiators - Monday, Dec 10, 2007 at 23:22
Hi KC
The Bi-80 has been discontinued and replaced with a DBi-120 which is basically the same thing but now rated at 120A and has the new switching voltages to suit the LC100 and others with lower alternator voltages. We have also fitted studs as the units with pre-fitted wires limit your mounting options.
Derek.
539892
