My 3 Way Fridge Fix
Submitted: Sunday, Dec 09, 2007 at 16:28
ThreadID: 52395 Views:4415 Replies:4 FollowUps:6
My 1989 caravan had a brilliant winter fridge that was dead set useless in summer. One February day (42 C) while comparing notes with a fellow camper whose fridge was working well, I persuaded him to take a look at mine. He walked to the side of the van, took one look and said "that will never work". The rear of the fridge had a vented panel from top to bottom. what I needed was a top vent and a bottom vent so that I could get convection happening (cool air in the bottom vent and warm air out the top). Home I went and removed my full length vented panel and bought a top & bottom vent kit. With the panel off, I could see that the fridge had a 60mm gap one side, 50 mm the other side and 150 gap above. This meant that any air that had ventured in to the rear of the fridge would have been totally confused about where to go. I bought a sheet of polystyrene foam (2400x1200x20mm for $24) and cut pieces to totally occupy the side gaps.This effectively added approx 50mm to the fridge sidewalls insulation. The top of the fridge had wiring and controls and wasn't suited to poly foam so I used block rubber foam over the top to occupy this large gap. All this meant that I had added enormously to the fridge insulation properties and had gained control of the cooling air movement. Additionally I installed an 80mm 12v fan about 250 mm below the condenser. I put a red illuminated toggle switch on the front control panel, picked up a power supply and wired it all together. Fan & switch $25 at DSE. Another piece of ally was used to manufacture a baffle from my new side wall panel to just below the condenser. That was all it needed. The air entering through the bottom vent stays only at the back of the fridge and can go nowhere other than through the condenser. The fridge now works magnificently and I have never turned the fan on. It's all about getting the airflow and directing it to where it's most effective.
Reply By: Bonz (Vic) - Sunday, Dec 09, 2007 at 17:18
Methinx theres thinking happening between them ears kev. Great writeup mate, thanx for that
AnswerID: 275793
Follow Up By: Member No 1- Sunday, Dec 09, 2007 at 18:42
mmm i would have replaced that 3 way with a compressor type as soon as i got the caravan....
FollowupID: 539634
Follow Up By: Motherhen - Sunday, Dec 09, 2007 at 19:33
As a paranoid gas fridge 'big bang' fearer, i must agree with Member No 1, although the advice Ozikev has given may help other who insist on using 3-way fridges.
FollowupID: 539652
Follow Up By: Redback - Monday, Dec 10, 2007 at 09:58
We have a 3way in our camper, and only have great things to say about it, summer or winter, in fact when it's on 12volt it has no ventilation, and as for hot days, it has always worked perfectly on gas when camped, in fact it can freeze if we leave it on high.
Also ours is from a 1974 Drifta poptop!!
Baz.
FollowupID: 539741
Reply By: Member - Phillip S (WA) - Sunday, Dec 09, 2007 at 18:59
Thanks for your story Kev....going to check mine out and see if I can do the same...cheers Phil
AnswerID: 275816
Follow Up By: Ozikev - Monday, Dec 10, 2007 at 07:59
Phil - as you are from WA you're more than welcome to contact me at Pinjarra and inspect what I did.
FollowupID: 539723
Reply By: Mike Harding - Sunday, Dec 09, 2007 at 21:38
Three way fridges are great providing one appreciates their limitations - just as one needs to understand the limitations of compressor fridges.
Mike Harding
AnswerID: 275844
Follow Up By: bruce - Monday, Dec 10, 2007 at 12:44
My opinion of 3 way fridges versus compressor ....for what it is worth...is this , a 9kg bottle of gas will run my 3 way fridge set on freeze for nearly 3 weeks...the cost of suppling power for a compressor (without solar option) fridge/freezer for the same period is not even worth considering ....even using battery power...the battery still has to be recharged somehow....solar , yes...but still expensive and if little or no sun then genny comes into play with its fuel costs and noise...... cheers
FollowupID: 539771
Reply By: Sacred Cow - Monday, Dec 10, 2007 at 13:54
Ozikev,
Thanks for this. I want to do the same. Please advise what "block rubber foam" is and where you buy it.
SC
AnswerID: 275931
Follow Up By: Ozikev - Monday, Dec 10, 2007 at 14:50
SC -' block foam rubber' is ordinary old foam rubber as in mattress type foam rubber etc. I had a 150 mm gap above the fridge and this foam rubber was ideal to push in there to occupy the space.
I had to get the incoming air moving up the back of the fridge and through the condenser and exiting through the top vent. All the gaps down the side of the fridge and above it detracted enormously from this happening. However, every cloud has a silver lining, and these gaps allowed me to put the polystyrene foam side panels in hard up against the fridge and greatly improve the insulation properties of the fridge. Looking at the back of my fridge now, I have no air gaps at the sides or top and all air entering through the bottom vent has to go up and through the condenser to the exit vent. Your case may be very different from mine. I had a fridge sitting in a big hole with no air going anywhere. Now I've filled up the hole and got the air doing what it needs to do. Boy what a difference !!
FollowupID: 539805
