What Generator to run Ibis (Aircommand) A/C ?
Submitted: Sunday, Dec 09, 2007 at 18:08
hazo
Wonder if anyone has been able to power up the new Ibis a/c from a genny? and if so what type and how big?
My Honda EU20i ran my previous Aircommand rooftop unit but drops out on overload with the new unit!
Been looking at the Yamaha 24i and 28i but cannot get confirmation it will handle the Ibis.without taking van to actually try it! which is a real pain to do!
Reply By: Derek from Affordable Batteries & Radiators - Sunday, Dec 09, 2007 at 18:19
Hi haza
Were are you ? If in
Brisbane you can test one of ours. The container will be here in Jan 2008 but the prototype is available for testing. 2.4 kva with 2.6 kva peak.
Derek.
275805
Follow Up By: Bonz (Vic) - Sunday, Dec 09, 2007 at 18:23
Hey Derek, How noisy are them bigger units?
539627
Follow Up By: Derek from Affordable Batteries & Radiators - Sunday, Dec 09, 2007 at 18:29
I have a Honda 2.0 and at the same load (my Air command slit system) they sound the same. If I run the a/c and my 30A smart charger the Honda trips but the new 2.6 unit increases revs slightly and noise goes up but only a bit. I don't have a db meter so can't say exactly but the specs are 60 - 65 db which I think is similar to the Honda. They also have 'Smart throttle' for lowering the noise.
539631
Follow Up By: hazo - Sunday, Dec 09, 2007 at 18:33
Thanks for the offer Derek but I'm in
Perth!
Its so bloody annoying as the new Ibis has exactly the same specs as the old unit but no way will it run with my Honda!
539633
Follow Up By: Member - George (WA) - Sunday, Dec 09, 2007 at 19:11
Hi Hazo, I'm in
Perth and if it helps you, I have a 2.4 yamaha you can try
539642
Follow Up By: Member - George (WA) - Sunday, Dec 09, 2007 at 19:14
Hazo, can you find out how many watts the Ibis draws, should be on the spec. page of the operating manual
539645
Follow Up By: hazo - Sunday, Dec 09, 2007 at 19:56
George
Its 3.2KW exactly the same as the Wren (old model) and maximum locked rotor current is 20A again the same as the Wren!
Silly thing is the run current is slightly less at 5.2A compared to 6.2A.
very strange.
Someone on the msn caravan
forum contacted Aircommand and they said they cannot recommend any generator to run the Ibis! but a minimum of 3.0KVA would be required ?
I'm just trying to find out if anyone has succeeded.
539659
Follow Up By: hazo - Sunday, Dec 09, 2007 at 19:59
Sorry George didnt read the other message first!
Where are you in
Perth?
I'm in Northern suburbs near Quinns rock/
Brian
539661
Follow Up By: Member - George (WA) - Sunday, Dec 09, 2007 at 20:42
Hi brian, I'm out your way tomorrow morning, around 8-8:30 but from your info I don't think a 2.4 yamaha will run your Ibis. However I would be happy to try it. Contact me on 0418 910 793 and let me know
539669
Follow Up By: unimog - Tuesday, Dec 11, 2007 at 21:24
He Derek, how's it going??
It's Hugo here, how about sending me them 8 or 9 bleep LED down lights that the Chinese factory replaced for you???
They were
mine remember???
customcoasters@yahoo.com.au
540035
Follow Up By: crayman 1 - Wednesday, Dec 12, 2007 at 15:59
Hi I have just ordered a new territory OFF ROAD VAN FITTED WITH AN IBIS hooked up my honda 20i ,starts and runs ok , salesman said some ibis units wont kick in with 2 to 2.4 yamahas also 20i honda`s air comard may retro fit soft start starters to all units , we wait and see??
Maurie
540142
Reply By: Faulic_McVitte - Sunday, Dec 09, 2007 at 18:40
mate my next door neighbour got a new van with Ibis and his Honda 20i would not run and tried Kipor 2600 and did not even attempt to start like Honda did. took it back to the dealer as dealer guaranteed Ibis would power from Honda 20i and had Domestic fitted.
275812
Reply By: Member - BIGDOG G (WA) - Sunday, Dec 09, 2007 at 18:53
G'day Hazo;
Just bought a coramal van with a new slimline Ibis, I dont think a 2kva would drive it so bought a 2.8 Yammy.
Havent got either at home yet (next week).
Will let yu know
Cheers...........BIGDOG
275815
Follow Up By: hazo - Sunday, Dec 09, 2007 at 19:50
Bigdog
Look forward to see how it goes.
I quite like the look of the 2.8 yammy and physical size- wise very similar to the Honda.
Hazo
539657
Reply By: Member Boroma 604 - Sunday, Dec 09, 2007 at 20:44
Gooday,
Go to caravanforum (not CARAVANERS) about the 11th topic down has a truck load of info on your problem, including advice from Air Command Head Honcho.
If I knew how to put the link on here I would but can get in enough notts without trying.
You will find they now need a Minimum 3kva.
Cheers, Boroma604.
275832
Reply By: frankn - Monday, Dec 10, 2007 at 09:15
Hi Hazo
I have a Ibis A/C in my Van and a 30 amp smart charger,my EU20i Honda runs them happily with no problem , it does't like running the Hot
Water unit it draws a line at that.You might need to get the output on the Honda checked out.
Regards Frankn
275900
Reply By: hazo - Monday, Dec 10, 2007 at 10:44
Well I can now confirm my Ibis will not run with a Yamaha 2.4i!
George was good enough to bring his round this morning to try. It attempted to start but almost stalled the yammy! then something clicks, in the Ibis, and it shuts down!
My only option now is to try a 2.8i or wait for Bigdog to try his when his arrives.
Thanks for all the help.
275910
Follow Up By: hazo - Monday, Dec 10, 2007 at 15:23
As a follow up,I have been in touch with Yamaha australia, and their state manager rang me to arrange a home demo of the 2.8i model.
Will be interesting to see if that does the job.
539810
Reply By: time waster - Monday, Dec 10, 2007 at 18:51
With the Honda are you trying the a/c with the smart throttle on because the load can be too quick for the revs to pick to match the load try with it off if you haven't already.
275976
Follow Up By: hazo - Monday, Dec 10, 2007 at 19:21
Timewaster
Didnt try it with the eco throttle on at all as I knew the load would be fairly heavy.
Disconnected everything else in van so only the a/c was drawing power.
539845
Reply By: time waster - Monday, Dec 10, 2007 at 19:55
Hazo is the Ibis a/c better than a heron 2.2 or just a more powerful unit?
275982
Follow Up By: hazo - Monday, Dec 10, 2007 at 21:18
Cannot really answer that one! I've had just about every combination of caravan type a/c and they are all noisy! compared to domestic systems.(some worse than others)
And are all "old" technology (non inverter systems)
I was going to have a domestic unit fitted in this new van but the manufacturer refused to do it!
In hind sight I should have ordered it without any and done a split install myself.
Some of the small inverter systems are said to be able to run happily off a 1.0kva genny!
539865
Reply By: PeterInSA - Tuesday, Dec 11, 2007 at 13:37
hazo,
You probably already tried this: I use a Honda 20i to drive my Aircommand. I turn the fan on first then 1 minute later turn the A/C onto cool, I was told this by Aircommand, it reduces the high starting current load on the 20i.
I tried lifting the Yamaha 24i in a
camping shop this morning its b... heavy.
276075
Follow Up By: hazo - Tuesday, Dec 11, 2007 at 16:27
The Ibis does not really give you that option, the fan comes on first anyway and runs fine, then after a short delay the compressor tries to start, it clicks a few times then shuts down!
Spoke to Yamaha again to-day and they said they did a trial with three Ibis equiped vans (all brand new) and two ran perfectly on a 2.4i, but the third would not start on a 2.4i,a 2.8i and finally started on a 3.0 kva model (but only just!)
Mine is obviously one of the latter!
I've sent an e-mail to Aircommand to day, exp[pressing my displeasure! will see if I get a reply!
539984
Reply By: hazo - Wednesday, Dec 12, 2007 at 14:54
Have had a call from my dealer in
Perth to day, they have been in contact with Aircommand who have admitted that there is a problem with a "small" percentage of Ibis a/cs running from a Yamaha 2.4 genny.
They are currently working on a solution (maybe a recall to fit a soft starter) to the affected units.
Again this info came from my dealer and not Aircommand!
I suggest anyone having problems to contact their dealer and Aircommand so that, pressure can be put on the manufacturer, and it can be rectified.
Due to the xmas holidays I have been advised to contact them straight after the xmas break and it will be put right.
Being the eternal cynic, mainly with caravan dealers, it will remain to be seen if they are true to their word!
276232
Follow Up By: PeterInSA - Wednesday, Dec 12, 2007 at 16:35
hazo,
Its a pity you cannot run the A/c on a Honda 20i, I think it is reasonably heavy for a fit 65 year old to lift in and out of a 4wd. I hope I can still do the lift when I am 70.
Maybe you should mount the Yamaha on the A Frame or change your A/C to a model that can run on the 20i, negotiate with Aircommand it may mean a bit extra cash but at least you will be able to lift the Honda. How much is not getting a bad back worth..
540147
