Sand camping
Submitted: Sunday, Dec 09, 2007 at 21:26
mchapo
I'm off to Fraser Island next year and need advice as to what type of tent pegs are best for the sand.I've looked at plastic and steel ones of all different lengths, but need your experience to make the right selection.
chapo
Reply By: Stu050 - Sunday, Dec 09, 2007 at 22:12
G'day,
We used the plastic sand pegs when we were there a few years ago. They were about 18" long from memory. Blew a howling gale one night, we ended up having 16 pegs on the windward side and 4 pegs in the lee. No problems, the tent stayed up, but the tarp over the cooking area was shredded.
275850
Reply By: Lyds- Sunday, Dec 09, 2007 at 22:47
are you sure you want to
camp on the sand? there a plenty of firmer
places to pitch a tent.
275858
Follow Up By: Geoff M (QLD) - Monday, Dec 10, 2007 at 10:10
It's pretty hard to find an alternative ...... seeing as Fraser is the largest SAND island in the world.
Just an FYI.
Geoff
539744
Reply By: Member - Bucky (VIC) - Sunday, Dec 09, 2007 at 23:37
Hey Chapo
I use metal star pickets, in sand. From memory I think they are 600mm long. Work a treat, they last for years, and you can double them up in almost any type of soil. Can't break them
Best purchased from a Hardware store.
Cheers Bucky
275865
Follow Up By: mchapo - Monday, Dec 10, 2007 at 00:32
Thanks Bucky , Good idea
539708
Follow Up By: Member - Bucky (VIC) - Monday, Dec 10, 2007 at 07:50
Sorry Chapo
Should have mentioned, you can get those star pickets in many various sizes, not just those ones the "cockies" use.
The concreter's use all different length ones, for their edging, and applications..
Cheers Mate
Bucky
539719
Follow Up By: Member - Bucky (VIC) - Monday, Dec 10, 2007 at 07:51
Sorry Chapo
Cheers Mate
Bucky
539721
Reply By: Member - MrBitchi (QLD) - Monday, Dec 10, 2007 at 08:52
Depends.. (doesn't everything ;-)) If you
camp, on the eastern beach in a howling south-
easter you'll need all of Bucky's star pickets and then some. If the weather is mild and you
camp ,in one of the designated
camp grounds then you'll just need a couple of normal steel pegs.
We usually
camp at the Maloo
camp ground just north of
Waddy Point and have never needed anything more than a few 300mm plastic sand pegs.
275889
Reply By: Shaker - Monday, Dec 10, 2007 at 08:57
Wooden tent pegs are the best in sand.
275893
Reply By: Ozboc - Monday, Dec 10, 2007 at 15:12
Hi we
camp at
Stockton beach a lot - and we use sand pegs - one advantage of
camping on sand is the surface is soft so easy to get a nice level floor without lumps especially good if you sleep on a thin mattress -
as others have suggested - plastic Spikes are good - the longer the better....
Bring twice the amount you need to use - ie your tent needs 8 -- you take 16 + even better 30
why ?
In very strong winds the single pegs can be ripped out easy as the sand is soft - so put your pegs in with a decent angle away from tent - then put 1 or 2 pegs to cross over the main peg - this will stop it being ripped out easily by wind -- i found this out the hard way -- had wind so strong one night it actually snapped one of those VERY flexible fiberglass poles ...
its also good practice to dig back the dry sand where your going to place the pegs ensuring that your pegs are going into the wet sand just bellow - this sand holds together much better and will provide a better anchor point ... then put a good mound of sand over the pegs .....
this i have learn t from a few years of sand
camping experience ...
Boc
275939
Reply By: Crackles - Monday, Dec 10, 2007 at 17:26
We use 4 metal angle iron pegs in the sand to keep our Freedom tent upright and have only had them pull out once when we decided to
camp in the scenic spot instead of going for shelter out of the wind. For side stays you can tie off to buried heavy duty plastic bags filled with sand. (Never pull out)
Cheers Craig............
275965
Reply By: Member - shane (SA) - Monday, Dec 10, 2007 at 20:16
hi chapo, what i use and have for 20 years or more is y12 rebar about 600mm long and with a large washer welded on top. the notches in the bar makes them hold really
cheers shane.
275987
