2004 100 series TD IFS lift
Submitted: Sunday, Dec 09, 2007 at 22:15
Name Not Found
G'day all, Long time reader first time caller. I have an 04 100 series TD on diesel/gas. I bought it to replace a 60 series TD due to the towing limit required to drag along a new purchase of a 7 metre powered catamaran, About 3200kg plus gear thereabouts. Trips range from runs to the local
boat ramp to trips up north (WA) 1200-1600 km each way. I needed some lift so installed polyair bags, with minimal effect. I went back to my local
suspension workshop and told him of this and instructed him that i would like to keep a reasonable level of comfort in the rear(not too firm a ride whilst not towing) did not want to sacrifice off road ability, and assist air bags in keeping car from dragging its bum up the road whilst towing my cat. He advised on a lift using springs, 1 stage higher than standard and we went ahead with that. It raised the car a little over 2". During the test drive it became evident that it had lost the steering ability to self straighten. Whereas normally from full lock the car would straighten it would instead do circles until manually steered in forward direction. Mostly when turning left but occassionly occurs when turning right. After adjusting the caster angle in the front, it occured less frequently but still happens in both directions which sometimes catches me by surprise. My
suspension specialist is out of ideas and his answer is to replace back to my original springs and wipe his hands of all 100 series IFS models. If anybody out there has had this problem or knows any way to rectify this problem, I would be most appreciative. Thanks in advance, Hawk1
Reply By: Stu050 - Sunday, Dec 09, 2007 at 22:42
Fit a "return to centre" steering damper and all will be good
275856
Follow Up By: TD100 - Monday, Dec 10, 2007 at 20:32
i would like to see where you bolt that up on rack and pinion steering ! LOL
539853
Reply By: Andrew(WA) - Sunday, Dec 09, 2007 at 23:09
Hawk
Where did you get the work done and what make springs did they fit?
Sounds a bit unusual, maybe the lift was too high!
I know you have to be careful on the front end with the IFS. You can't go too high, only stiffen it up a bit.
Never heard of it before and I've been reading threads on here for about 5 years.
Let us know if you sort it out. Good luck
275859
Reply By: vuduguru - Monday, Dec 10, 2007 at 05:56
I had my
suspension lifted last week (F&B) + a diff drop kit. Had exactly the same problem. Dropping the front a bit helped. Maximum 70mm droop was the figures I has told to observe. Castor should be close to zero.
Mine still exhibits this reluctance to return to centre but only a little.
I' d be interested to hear if the steering damper cures the problem.
275873
Reply By: GaryW - Monday, Dec 10, 2007 at 08:28
Hawk,
I have a 2004 IFS TD 100 Series with a full OME kit resulting in a 2" lift in the rear (200kg Constant Load rear springs) the front T'Bars were replaced with OME ones and wound up 25mm from standard I then put 285/75/R16 Tyres on. I have never noticed the steering issue you mention.
G
275878
Hawk,
G
275879
Reply By: Member - DOZER- Monday, Dec 10, 2007 at 20:39
Give Darren a call at ATS 4wd in
Melbourne, he will give you good advice...sounds like the diff lowering has something to do with the defect, as the ome doesnt exibit thesame issue.
275993
Follow Up By: Member - DOZER- Monday, Dec 10, 2007 at 20:41
OH YEAH...the last time i tried the RTC steering damper, i was very unhappy with the varying effort needed to hold the steering straight, on different camber roads....whats straight on 0 camber is steer right to keep straight on cambered roads...rubbish i thought
539854
