solar panels
Submitted: Monday, Dec 10, 2007 at 21:22
ThreadID: 52435 Views:3456 Replies:7 FollowUps:9
hi guys n girls!
just wondering what would be the best wattage solar panel to trickle charge my aux battery during the day that runs my 30L engel.
Reply By: GerryP - Monday, Dec 10, 2007 at 21:56
Hi Gregs,
I have a portable 80 watt panel which lets me keep my 40 litre Engel going on my auxilliary battery (N70 deep cycle) without any problems. In fact, I usually rotate between the aux in the car and the batteries in either the caravan or the camper trailer and have never yet run out of juice.
Gerry
AnswerID: 276004
Reply By: domlc100 - Monday, Dec 10, 2007 at 22:02
Hi Gregs GQ , Your engel will draw about 2.5 amps so a 37 watt panel will supply about 2-2.5 amps max, 68 watt panel will supply about 3-3.5 amps and a 80 watt will supply about 5-5.5 amps but keep in mined that this is in full sun and the correct angel to the sun. I would run at least an 80 watt panel so you can supply some charge for the overnight running time and for couldy days. Hope this was some help.
AnswerID: 276005
Reply By: Derek from Affordable Batteries & Radiators - Monday, Dec 10, 2007 at 22:40
Hi Greg
Remember you need to replace in 8 hours what the fridge uses in 24 hours. Your battery size and type will also influence the equation and there are other variables. Based on my experience I would recommend a 80W panel for a 30L to 40L fridge.
Derek.
AnswerID: 276018
Follow Up By: Member - Matthew C (WA) - Monday, Dec 10, 2007 at 22:48
What brand and whereabouts are you guys buying these panels from.
Matt
FollowupID: 539882
Follow Up By: Derek from Affordable Batteries & Radiators - Monday, Dec 10, 2007 at 23:12
Hi Matt
I use BP Solar and GP Green Power both from China. I do have a few of the old Australian made single 80W panels left. Quality and construction is the same using a 50mm aluminum frame.
Derek.
FollowupID: 539889
Follow Up By: Member - Matthew C (WA) - Tuesday, Dec 11, 2007 at 00:30
Can you point me towqards a link or where to get them derek.
Matt
FollowupID: 539896
Follow Up By: Member - Phil G (SA) - Tuesday, Dec 11, 2007 at 07:26
Matt,
Derek is an Exploroz advertiser. Just click the link on his signature, and then click contact details.
FollowupID: 539903
Follow Up By: Faulic_McVitte - Tuesday, Dec 11, 2007 at 08:21
bought couple of 85w suntech mono crystal at $625 each
incredilbe to see 11 amps charging the battery
FollowupID: 539912
Follow Up By: Derek from Affordable Batteries & Radiators - Tuesday, Dec 11, 2007 at 08:41
Hi Matt
As you are in WA you should try one of the local suppliers. You will save on freight costs and I am sure they will price match for you.
Derek.
FollowupID: 539916
Reply By: Member - Hurkmagurk (WA) - Tuesday, Dec 11, 2007 at 13:12
Solar Sales in Belmont
AnswerID: 276072
Reply By: Wizard1 - Tuesday, Dec 11, 2007 at 14:41
The only thing that keeps me away from solar is the setup cost. I already have a Honda EU20, but want to do the right thing when I can as well.
I don't want a permanent setup in the van so the portable style panels seem the go. But the price. They are all around $1000 or so for a 80 Watt with all the bits.
Add a good 100 AH battery, a good 240V switch mode charger and there isn't much change out of $1500. Ouch
I guess I could plough through Ebay but don"t have the time..
So how does one get a reasonably priced 80 Watt portable solar panel for under a $1000?
AnswerID: 276083
Follow Up By: porl - Tuesday, Dec 11, 2007 at 16:05
Hi I tried to day to put my kit up for sale on trader but I already got my wagon for sale there so I'll have to pay to put my solar panel up - which I don't mind but I don't have any pics at the moment.
They are 2 x 40w BP Solar SX40W putting out max 2.37amps each. I have them connected together (home job) and a steca solarix regulator and 6m or so of decent wire to the alligator clips.
Why selling ? They just haven't suited my style of set up camp and wander off for most of the day. i have never wanted to leave them out (safety issue, i mean they aren't cheap) so have never really used them. I have a generator so now letting go of the things I don't use.
A price ? Well whatever is reasonable. I live in Brisbane. Tel: 04 3846 3846, if you txt me interest I'll send you an email address, I can txt you or email you pictures. They are in perfect condition. Would take 2min to separate them.
I'll put them in the trader section soon if I don't hear from anyone.
I am thinking about $700 but based on what someone said below I understand that might be a bit high.
prol
FollowupID: 539981
Reply By: yakodi - Tuesday, Dec 11, 2007 at 15:21
Gday - just setup 80watt Bp solar panel with 6 amp morningstar and wiring, and aluminium brackets, for approx $770 plus some monts for rhino commercial rack. Fitted in roof rack, panel was not too big and powers our 40l engel plus camp light and water pump in c/van. Thought this was most practical as we leave the caravan behind to go camping with the knowledge that we have a power supply. Lasts approx 3-4 days without running vehichle. More often than not we start the car for day trips. So far the regulator always states that we have a fully charged battery or near abouts. Purchased setup at Cairns solar suppplies - very helpful staff. .
AnswerID: 276090
Reply By: Ozboc - Tuesday, Dec 11, 2007 at 16:14
Has anyone bought any of those solar panels from ebay or the ones from GREYS online that someone else mentioned a few days ago ??/
Boc
AnswerID: 276100
Follow Up By: Cobes - Tuesday, Dec 11, 2007 at 21:32
Hi Boc,
A few months back I purchased a brand new Sharp 80watt panel from the environment store on Ebay. The tranaction was very easy and the panel is great. I paid $580 for the panel which I think is a good buy.
Chris.
FollowupID: 540040
Follow Up By: Member - Mainey (wa) - Wednesday, Dec 12, 2007 at 09:30
Chris,
that's because Sharp are a quality built product, unlike some another elcheapo brands available.
Sharp are a Japanese company and have been producing Solar panels for over 30 years, they are not a cheaply made product that uses elcheapo parts or dodgey technology.
FollowupID: 540092
