Help needed with Aussie truck mirrors.
Submitted: Wednesday, Dec 12, 2007 at 19:09
herkman
We are trying to fit these to a 2005 Prado.
However where the mirror bracket goes down between the door window seal, and the drop glass, it rubs on the glass.
Is actually taking the window tint off.
Can others please advise on how they resolved this situation.
Col
Reply By: Dunco (NSW) - Wednesday, Dec 12, 2007 at 19:52
The window tint should be on the inside ?????
Just make sure you follow the instructions...you must be doing something wrong as I use them on my LC100 and have NO PROBLEM
Make sure the arm that the mirror sits in is at RIGHTANGLES to the door as if they are not they will rub on the window...that is the only thing I can think of. It cannot be at an angle...should be at 90 degrees !!!!
276286
Reply By: rodeodude - Wednesday, Dec 12, 2007 at 21:26
hI
The only prob i know with the prado is you need another strap to suit the bottom of the door sill, otherwise they are a great mirror
Rd
276307
Reply By: Member - Cruiser (NSW) - Wednesday, Dec 12, 2007 at 23:02
I have the same problem. They fitted on my 80 series fine, but not on the Prado (
mine is an 04). The not only scratched the glass, but also damaged the rubber seal, so I now dont use mirrors at all.
Cruiser
276329
Reply By: Member - Bucky (VIC) - Thursday, Dec 13, 2007 at 04:44
Get a reversing camera !
Bucky
276343
Reply By: Member -Signman - Thursday, Dec 13, 2007 at 09:36
There's an article in the current CMCA magazine about 'copy' Aussie truck mirrors. Apparently the mirror & the packaging look very similar to the original.
Users have commented about difficulty in fitting, and the plating falling off after a short time.
276361
Reply By: herkman - Thursday, Dec 13, 2007 at 16:34
Thank you all for your kind help
Col
276427
