Vacuum toilet
Submitted: Wednesday, Dec 12, 2007 at 19:23
ThreadID: 52494 Views:7295 Replies:6 FollowUps:6
Hello again
One of the van's I'm looking at has a vacuum toilet. Are these better or worse than a standard vacuum toilet?
Reply By: Shaker - Wednesday, Dec 12, 2007 at 19:24
Please explain?
AnswerID: 276278
Follow Up By: jdbb - Wednesday, Dec 12, 2007 at 19:36
I'll try.
Standard cassette toilet = cassette with chemicals is below toilet, waste goes in, chemicals do their work, cassette is removed and emptied, chemicals added etc.
Vacuum toilet = waste is removed by suction, goes through some sort of grille and broken up, ends up in cassette that is removed and emptied. No chemicals required to break up solids. The one I saw had the cassette about 8' away from the toilet.
FollowupID: 540176
Follow Up By: jdbb - Wednesday, Dec 12, 2007 at 22:31
Oops - now I understand the please explain - sorry about that.
Thanks for the replies.
FollowupID: 540230
Follow Up By: Member - joc45 (WA) - Thursday, Dec 13, 2007 at 11:20
Glad you cleared that up!
I got the impression that it was an attachment to the body orifice.
FollowupID: 540289
Reply By: flatout - Wednesday, Dec 12, 2007 at 19:41
John fitted dometic vacuum wc with 14l cassette about 2 years ago best thing ever no smell no chemicals.
love it
regards ron
AnswerID: 276283
Follow Up By: Lyds- Wednesday, Dec 12, 2007 at 21:43
"no smell"?
sounds like a challenge to me :-)
FollowupID: 540217
love it
regards ron
AnswerID: 276284
Reply By: lifeisgood - Wednesday, Dec 12, 2007 at 20:23
You meant to say "standard cassette toilet"
I have heard no smell inside van so good--- but dont park next to one because the smell goes out the side vent instead. ie when the chamber vacuumn is restored after use. It has to pump the evacuated and smelly air somewhere!! No stink pipe up to the roof like on houses.
There is also more noise from the pump (especially at night) and power drawn from the battery.
Just what i have read. Have a simple cassette myself and use eco fluid to break things up and take care of odours.
AnswerID: 276294
Reply By: Member - JohnR (Vic)&Moses - Wednesday, Dec 12, 2007 at 20:42
John, have a vacuum toilet in our Karavan. I much prefer it to the chemical toilets I have had experience with. Apart from the small smell when you unplug the casett from it's mount there is no smell, oh, except emptying as there is with either.
No chemicals means it doesn't upset the septic tanks that seem to abound in country caravan parks.
It uses small quantities of water to keep it going and any noise is minimal. It is just like an aircraft toilet except for the lack of aircraft noise and more room when you are in the toilet. It is great and obviously the negatives commenting have never used one.
AnswerID: 276296
Follow Up By: Member - BIGDOG G (WA) - Wednesday, Dec 12, 2007 at 22:52
Well I have used lots of them, Planes, boats and thru Europe.
I have never used one in a van but I cant imagine they are any quieter.
Everytime I use one, 'WHHHHOOOOOSHSHSHSH' I always say
Oh shyte, Ill never get used to that.
Would be a hell of a racket in a cp at 3am.
Cheers.............BIGDOG
FollowupID: 540236
Follow Up By: Member - JohnR (Vic)&Moses - Thursday, Dec 13, 2007 at 07:48
Big and little dogs, usually can't make it past the wheels mate. LOL They crap away from the van too.
I seldom hear the vacuum noise at overnight, or the vacuum pump either.
FollowupID: 540259
Reply By: RovingOz (QLD) - Thursday, Dec 13, 2007 at 10:35
A LOT more to go wrong but there are very few reported problems with them. Biggest is leaks in the system especially the waste pipe but that usually comes back to installation problems - waste pipe also needs to be well protected from road damage.
The maintenance is important but the supplied manual doesn't provide very good info.
I visited the Dometic Qld and was given a complete run down on what to watch for.
To keep it maintained you need silicone spray, a good vacuum grease and plenty of Aqium! :-)
AnswerID: 276377
