L/CR rear brake pipes
Submitted: Wednesday, Dec 12, 2007 at 20:03
ThreadID: 52495 Views:2124 Replies:2 FollowUps:1
hi landcruiser lovers
I have a ld/cr 79 series with airlift air bags on removing a rear wheel i discovered that the flexi brake pipe behind disc was rubbing on air bags
whats a good way to solve this problem? put a split wireing cover!
cheers reggy2
Reply By: Dave B (NSW) - Wednesday, Dec 12, 2007 at 20:44
I would pull the pipe away from the airbag reggy.
I think if you put split wireing covering over the brake pipe, you will just create another rub point on the airbag.
Get rid of any rub points, even if it means getting a longer flexi brake hose fitted.
'Wouldn't be dead for quids'
AnswerID: 276297
Follow Up By: Member - reggy 2 (VIC) - Wednesday, Dec 12, 2007 at 22:03
good point dave i was only thinking of brake pipe air bags are exspensive i was thinking of running out of brakes when in high country thanks reggy2
FollowupID: 540222
Reply By: Member - Phil G (SA) - Thursday, Dec 13, 2007 at 10:35
reggy2,
You'll prpbably find that the top end of the hose is held by an angle - you can loosen the bolt holding it and rotate a little. I rotated mine to get the max length after fitting longer-travel shocks, but maybe you can rote it so the hose is clear of the bag.
phil
AnswerID: 276378
