for all those who are smarter than me
Submitted: Wednesday, Dec 12, 2007 at 21:25
ThreadID: 52497 Views:2307 Replies:10 FollowUps:10
Trying to work out the GPS right (Magellan Explorist 500) and when we attatch the USB cord (is that what its called - the thingy that goes into the computer which is attached to the GPS) it says that it cannt recognise what it is........is this normal and how is it fixed.
It did come with a cd but I think that had to do with registering it etc....Nathan dealt with that bit.....
and also does Discover aus streets and tracks version 2001 go with it.....cannt seem to get it to work...borrowed cd....but this could be due to the computer not recognising it.....
HELP!!!! Any Idea and whats going on????
Laura
Reply By: Redback - Wednesday, Dec 12, 2007 at 21:31
Your doing something wrong!!!
Get the correct CD!!!
AnswerID: 276311
Follow Up By: Redback - Wednesday, Dec 12, 2007 at 21:35
Oh the CD is probably the installation disc and you need this as it tells the computer to recignise the USB port and GPS.
ALSO READ THE INSTALLATION GUIDE
FollowupID: 540208
Follow Up By: Kiwi & "Mahindra" - Wednesday, Dec 12, 2007 at 21:35
sweet....thats what we thought....we were a little sus when we put the cd in and our type didnt come up to choose from.....
but recognising the USB cable....????
FollowupID: 540209
Follow Up By: Kiwi & "Mahindra" - Wednesday, Dec 12, 2007 at 21:38
even without the program running the cable isnt recognised. Its not the installation cd,but the actual program.....can view streets / hwys etc but when it comes to the gps nothing wants to work on the computer......sorry if i saound really dumb on this stuff but I just cannt get my head around it.....couldnt even work the other gps we had properly (although Nath could....)
FollowupID: 540211
Follow Up By: Redback - Wednesday, Dec 12, 2007 at 21:41
It might be that your putting a USB 1 cable into a USB 2 port.
FollowupID: 540214
Follow Up By: Kiwi & "Mahindra" - Wednesday, Dec 12, 2007 at 21:42
tried both....still no good
FollowupID: 540216
Reply By: TD100 - Wednesday, Dec 12, 2007 at 21:37
Kiwi,
if i plug something foreign into a USB my PC will run the appropriate programfor it or if it cant find it asks me if i want to search the internet to find it,walah job done usually.on the odd occassion it may not find the software reqd.hope this helps.cheers Paul
AnswerID: 276313
Follow Up By: Kiwi & "Mahindra" - Wednesday, Dec 12, 2007 at 21:40
Same but not in this case....I can usually figure things out if it gives me a choice..LOL..
I just tried putting the CD in that came with it and re doing that to see if that made a difference but so far no good....
Laura
FollowupID: 540213
Follow Up By: Kiwi & "Mahindra" - Wednesday, Dec 12, 2007 at 21:41
it tells me that the USB cable has malfunctioned and windows does not recognise it.....
FollowupID: 540215
Reply By: Redback - Wednesday, Dec 12, 2007 at 21:52
Hi Kiwi
I highly recommend you go into Start>Settings>Control Panel and use the 'Add Remove Programs' program to uninstall anything that was installed for the GPS.
Reboot computer
Read the installation guide and follow it's instructions. Generally you will need to install the software first, then connect the device when prompted. Connecting the cable is not sufficient as the computer doesn't recognise it as being anything (its kinda like an extension cable). You will need to plug the GPS into the cable and turn it on.
If that doesn't work try plugging it into another USB port. It shouldn't make a difference which port it is in, but sometimes it does.
If all that doesn't work you will need to wait till the morning and ring the support section of the manufacturer, or whoever you purchesed it from. There may be something wrong with the installation disk or the device itself.
AnswerID: 276317
Reply By: jonl - Wednesday, Dec 12, 2007 at 22:30
I have had trouble with the explorist 500 and the usb port recognizing it there is a small program called 'gpsportchecker' if you get that from the internet it will find the gps, if every thing else is ok.
regards
Jon
AnswerID: 276322
Reply By: Member - Bucky (VIC) - Thursday, Dec 13, 2007 at 04:08
Laura
Redback is right on the money there !
Uninstall everything associated with the GPS.
And start again ....
Then R T F M !
Cheers Mate
Bucky
AnswerID: 276342
Follow Up By: Kiwi & "Mahindra" - Thursday, Dec 13, 2007 at 07:06
done all that Bucky!! twice!! LOL ......maybe we got a dud! Then i would laugh....got ta gps older the other day from usa and it was suppose to hold the thing and it dont!!
Gonna try that gpsportstracker
nice fox story too!! i can just imagine it....you stumbling all over the place, bullets going everywhere!!
Laura
FollowupID: 540253
Follow Up By: Member - Bucky (VIC) - Friday, Dec 14, 2007 at 07:02
Laura
Does the GPS work outside and do its locating thing ?
Took me a while to get ours working on the puter.
Keep tryin, or another thought take it around to someone else who has the same, and try to get it working on their puter !
LOL
Bucky
FollowupID: 540452
Reply By: obee - Thursday, Dec 13, 2007 at 09:24
I had a prob with the cable (Expl400) right from the start but didnt realize till late and had to buy a new one. The fact that the computer can see something it doesnt recognise tells me that the signal is getting through and computer hasnt relevant software.
Maps come on sd cards from the manufacturer/seller. The old ones on cd you can forget.
good luck
owen
AnswerID: 276360
Reply By: QLD Kev & Darkie - Thursday, Dec 13, 2007 at 12:48
Simple answer is to get rid of the Magellan Explorist 500 and buy a Garmin LOL
Cheers Kev
I have NFI what your problem is
Russell Coight:
AnswerID: 276398
Follow Up By: Kiwi & "Mahindra" - Thursday, Dec 13, 2007 at 12:58
Ill answer your comment Kev.....I got a Garmin!!....took me 6 weeks to work that thing out and then we came home and never got it out of the draw!!
My prob is that maybe im a little foncused!!
2mrw friday shall i remind you??!!
FollowupID: 540299
Reply By: HGMonaro - Thursday, Dec 13, 2007 at 13:10
I only have a old version of DAST but it has a menu option called Options, GPS Settings. When selectiong that for the 1st time it attempts to locate the GPS (would need the GPS plugged in). have you tried looking in DAST for something similar.
AnswerID: 276400
Reply By: mick smith - Thursday, Dec 13, 2007 at 19:04
The down side of this is you will get no help from the distributor,at least i haven't.They are in WA and are a complete joke.I have had no response from any of the emails i have sent to them.There is a dude on here somewhere that can help you i think,just have to do a lot of searching.gpoz maybe....Updates are non existant as far as i can tell...but...i am a computer spastic too!
Good luck...I will be watching this thread for the right goodies!
Cheers Mick
AnswerID: 276468
Reply By: Gob & Denny(hampton park vic) - Thursday, Dec 13, 2007 at 20:36
when all else fails try ringing oziexplorer (i think thats the people that have all the leads and stuff )and see if theyb have time for va chat about your problem they are pretty smart people
steve
AnswerID: 276491
