Google Earth , GPS & Real Time Tracking (VIEW)
Submitted: Thursday, Dec 13, 2007 at 13:15
ThreadID: 52518 Views:2978 Replies:3 FollowUps:2
Hi All, Just wondering if someone could help me with the following.
I have Google Earth tracking via my GPS however it zooms in all the time, so close that I can't see a decent satellite view. I have checked all the settings and can't see one for changing the view of my current position , it's currently zooming in to around 4 metres which blurrs things and when I try and zoom out it zooms back in again. ?
Any ideas..?
Reply By: Member RayJen Paj05 (NSW) - Thursday, Dec 13, 2007 at 14:22
I can only suggest looking at the GE User Guide: try
http://earth.google.com/userguide/v4/ug_3dviewer.html ;
that has a reference to Zoom controls.
Hope this helps, Cheers, RayJen
AnswerID: 276412
Reply By: Member - Andrew (QLD) - Thursday, Dec 13, 2007 at 14:25
From the Google Earth Plus forums:
"I am a Google Earth Plus subscription associated. When I connect my GPS to use with Google interface in the "real time tracking", the image keep zoomig in until (7m) from ground. How can I set up a limit for this zooming in process and, for example, lock it on 1,0 km above the ground, for better visualization?
====reply====
You cannot lock it to 1 KM high, which is probably too high to track movement unless you are flying a plane. But you can get a better view. Switch your GPS between NMEA format and Garmin format and set Google Earth Plus to the same setting. One of these formats has a better view than the other.
Hope this answers the question.
AnswerID: 276414
Follow Up By: TerraFirma - Thursday, Dec 13, 2007 at 14:34
Can switch from Nmea format to Garmin etc but not sure how to set Google Earth to the same setting, can't see anything for that..?
FollowupID: 540316
Follow Up By: Member - Andrew (QLD) - Thursday, Dec 13, 2007 at 14:51
Don't know as i don't use the GPS functionality....sorry.
FollowupID: 540319
Reply By: TerraFirma - Thursday, Dec 13, 2007 at 15:29
Looks like that once you start driving it zooms back out so you can see yourself driving along with a reasonable view, so I'll see how it goes, thks..
AnswerID: 276420
