ozieplorer, how to load NatMaps
Submitted: Thursday, Dec 13, 2007 at 18:13
Member - George (WA)
I have loaded the NatMaps on my hard drive in Ozieplorer, including the map files. However, every time I try to load a map image the program asks me to insert the CD1 disk in D drive. How do I over come this
Reply By: Jimbo (WA) - Thursday, Dec 13, 2007 at 18:35
George,
It's hopefully as simple as going to file / configuration / map images and making sure the image file path reflects the correct folder where you put your maps.
Hope this sorts it,
276461
Follow Up By: Member - George (WA) - Thursday, Dec 13, 2007 at 18:56
Thanks Jim, but that made no diference
540354
Reply By: Gramps (NSW) - Thursday, Dec 13, 2007 at 19:25
George,
In Ozi, under File, select "Change Image File Name, Path & Drive"
I think it's the third option "Change Drive Identifier ...... "
(I hope this only submits once !!!! )
276471
Follow Up By: Member - George (WA) - Thursday, Dec 13, 2007 at 21:02
Hi Al,
You have hit the nail on the head. Your advise did the job perfectly, thanks very much
540387
Follow Up By: Gramps (NSW) - Thursday, Dec 13, 2007 at 21:30
Happy to help.
540395
Reply By: Member - MR 1927 (NSW) - Thursday, Dec 13, 2007 at 20:45
George,
I think you will find there are no maps on the Oziexplorer CD other than practice maps.
I believe you have to purchase the Maps on separate DVD's such as "Australia 4WD Raster Map Collection" and load the maps from the DVD.
On the back of the Oziexplorer CD is a note, quote, "No usable maps are provided with this package only example maps."
I hope this helps as I had the same trouble.
Good luck!.
276494
Reply By: Skippy In The GU - Thursday, Dec 13, 2007 at 20:49
Or you could copy and paste the 250kecw & Natmap 250K Mosaic.map into the map folder in Oziexplorer
276496
Reply By: Member - George (WA) - Thursday, Dec 13, 2007 at 21:04
Thanks to everyone for your input, but Gramps had the right info which did the job
276513
