Polyairs going on
Submitted: Thursday, Dec 13, 2007 at 20:34
Kiwi & "Mahindra"
Booked in to get them put on tomorrow and still got to do the floor over the draws.....
so....gotta get a fridge slide.....last one we had in the LC was home made.....the runners for it were out of the in laws old kitchen so never actually bought them.....so if I went to a kitchen
shop or any other type of
shop, how much would i get set back for ones 750mm long???
Ive looked on ebay and there are some there but I dont have time to wait for postage unless its sooper dooper quick...
Laura
Reply By: kmyers - Friday, Dec 14, 2007 at 00:57
If you are looking for draw runners that can take the weight and are of good quality hafele would be a good place to start. They have centers in every major city, and if they don't have it they will get it in a couple of days. Their range is huge, they have a sight that has their cataloge. My fridge slide is made out of a old teachers desk that had a filing draw in it. Had to extend it by 20cm or so but does the job. A 40L engel with bag fits perfect. Has a bolt going through the base into the floor, which was already there. Cost $0.
276559
Reply By: Member No 1- Friday, Dec 14, 2007 at 11:31
whish ever you get make sure they dont have nylon tyres...although they make for quieter operation they crack after awhile and you'll need a new set of runners... spare nylon outer sleeve/tyres are not available as I have found out.
Jimbo make fridge slides
276614
Reply By: Member -Signman - Friday, Dec 14, 2007 at 14:18
I've got a (proper) fridge slide for sale..750x400mm
MM if interested !!
276638
Follow Up By: Kiwi & "Mahindra" - Friday, Dec 14, 2007 at 14:32
I am going to look like a real ditz....havent been on ebay for a few days...i put a bid on some and won.....woops....anyway...not so bad....just hope they post asap!!
your size'd fit too (i think)
Laura
540508
Follow Up By: Member -Signman - Friday, Dec 14, 2007 at 14:43
No probs...
You still organising a trip in the New Year??
I'm off to the Vic. High Country Jan 12-19th..
540513
Follow Up By: Kiwi & "Mahindra" - Friday, Dec 14, 2007 at 14:51
Yep for sure....just trying to get my head into gear for packing up christmas stuff to go away with....
long weekend sound ok?
vic high country sounds divine this time of yr!
Laura
540516
Reply By: Member - joc45 (WA) - Friday, Dec 14, 2007 at 14:40
Laura,
Re the Polyairs, (I'm very happy with them) just check with the installer where they are going to put the inflation valves. The first set I had installed, the valves were mounted right out proud on the bumper stops, neatly set up to be clobbered by the first thing I backed into.
Next time around, in advance I sussed out a nice protected place for the valves, then told them to bung them there.
Gerry
276642
Follow Up By: Kiwi & "Mahindra" - Friday, Dec 14, 2007 at 14:54
got the valves put on the rear step tucked in besides the lights for rego plate....tucked away so all good for knocking them...
Bucky got his put next to the fuel
tank filler...in there....that'd be a good spot too....
the bloke wants to see how they are working when she's fully loaded....thinks they n=might pop out the side of the spring and rub on the shock....LH side only...
Laura
540518
Reply By: richard cee - Friday, Dec 14, 2007 at 23:55
I'm looking at Polyairs or similar for my 2004 Pajero, can you let me know who in metro area sells and approx prices and fitting cost. Many thanks.
276741
Follow Up By: richard cee - Friday, Dec 14, 2007 at 23:56
Oops, should have mentioned in the mighty West Aust. metro area.
540596
Follow Up By: mike w (WA) - Saturday, Dec 15, 2007 at 16:10
Richard,
Me and another are currently looking at getting some coil rites from the US. Damn cheap and easy to install. If your interested in getting at the same time, we may be able to save on freight.
Have a look at trucksprings.com , find out what model you need and let me know. We will be ordering next week sometime.
540663
Follow Up By: richard cee - Sunday, Dec 16, 2007 at 13:06
Mike, Firestone part no. is FIP 4125. From checking etc Trucksprings may not be able to supply as this is not applicable to the current model Mitsubishi's over in USA. More than happy for you to try and order the above with yours and if it happens great.
What car/4WD are your coil rites for.
Thanks, Richard.
540773
Follow Up By: mike w (WA) - Sunday, Dec 16, 2007 at 14:19
No probs Richard, I shall ask the question. Im ordering for a Jackaroo.
Mike
540786
Follow Up By: richard cee - Tuesday, Jan 08, 2008 at 22:48
Hi Mike
Any luck with your and my coil rite part numbers and if they can supply.
Thanks, Richard.
544764
Follow Up By: mike w (WA) - Wednesday, Jan 09, 2008 at 19:48
Richard,
they are a little slack in getting back in contact. I shall try calling them tomorrow
Mike
544925
