OziExplorer CE - Development Version - New Version
Submitted: Thursday, Dec 13, 2007 at 22:01
The Explorer
From OziExplorer webpage
OziExplorerCe
Development Version 2.00 (December 2007)
Changes
There have been numerous changes, below is a list of just some of the major ones.
Multi page support with screens that can be designed by the user using a program which runs on a PC.
More than 50 new parameters have been added.
Profiles for altitude and speed.
If the Communication Port is set to "Auto" it will search all serial ports at all baud rates for a GPS which is outputting NMEA.
Compass for navigation to next waypoint.
3 Odometers are available for measuring distance.
Sounds good
Reply By: Richard Kovac - Thursday, Dec 13, 2007 at 22:38
Greg Hi
Is this something you update your old CE version or something that run standalone?
I down loaded something like this one other time but got to frighten too install it.
and whyle I,ve got you I have OziExplorer on my NavNet system, when I try and load track file, onto it the whole track will not load ie. planed trip Anne Beadell hwy on the track will only go for 1 th the way?
it's ok on the home PC only NavNet seems to give a problem, it's like it's a point problem as CE has the same problem..
Richard Kovac
276537
Follow Up By: The Explorer - Thursday, Dec 13, 2007 at 23:28
Hello - the new version loads into a separate directory and therefore doesn't interfere with older version - i.e. you can have a play. I am however currently having an issue with it not recognising serial code - keeps plastering 'demo version' on my maps despite entering correct code?? Maybe problem my end?
With respect to you second question - OziCe will only display maximum of 1000 track points, PC version has no limitation from memory ...not sure about navnet (never actually heard of it).
540437
Follow Up By: Richard Kovac - Friday, Dec 14, 2007 at 00:44
Sorry greg
Navnet is a in car PC windows XP running full version og Ozie and it is like "will only display maximum of 1000 track points" but can not seem to fined the setting in config to change
Richard
540445
Follow Up By: Member - Gomax (VIC) - Friday, Dec 14, 2007 at 12:06
Same demo mode problem here, crossposted on OziCE
forum, other user posted same prob, so will wait & see....
540487
Follow Up By: Member - Andrew (QLD) - Friday, Dec 14, 2007 at 12:34
mine seems ok, though i did get a new serial code (read: payed up again) for OziCE about 3 weeks ago. Maybe it has changed recently? I haven't been able to check if my old one and this new rego code is the same.....
540489
Follow Up By: Member - JohnR (Vic)&Kath - Friday, Dec 14, 2007 at 19:19
Thanks for the advice Greg. I haven't had the problems you describe, the program recognised the name and Device ID so it was registered ok. I did a couple of installs though.
540544
Reply By: Member - Andrew (QLD) - Thursday, Dec 13, 2007 at 23:13
Wow, i have finally seen what a development version of OziCE looks like in my lifetime :-) Now we need to wait another couple of years for Ozi3D to become non-beta.....
(all tongue in cheek of course)
Thanks for the reminder Greg.
276553
Reply By: Member -Signman - Friday, Dec 14, 2007 at 10:19
Hooray for the compass!!!
That is one feature that's missing on current CE...
276608
Reply By: Member -Signman - Friday, Dec 14, 2007 at 19:22
Wow- just got home and loaded it up.
Did the usual config. stuff and away it went. Enough features to keep me busy for a while !!
No probs. installing- loading- config etc.
Just fired up and all good!!
276687
Follow Up By: Member - Matt M (ACT) - Saturday, Dec 15, 2007 at 09:24
Just loaded it as
well Signman and it looks great. Don't know how I am going to play with all those new features AND answer the mobile at the same time.
Matt.
540612
Reply By: Member - Gomax (VIC) - Saturday, Dec 15, 2007 at 09:03
For those with registration problems.
Email the developer
info@oziexplorer dot com
with details of your user name and code number.
A new code will be issued.
Keepin' it ontrack
Cool Yule
276751
Reply By: Member - Brett (WA) - Tuesday, Dec 18, 2007 at 09:53
This update is GOLD!!! Great new features, done
well guys!
Cheers for that!
277215
Reply By: The Explorer - Tuesday, Dec 18, 2007 at 16:27
Got my new reg code and all is sweet - new pages and customisation features are a great boon. Got in trouble for playing with it in bed last night (the PDA/OziCe that is:)
277270
Reply By: The Explorer - Wednesday, Dec 19, 2007 at 19:09
As one would have anticipated ..a new version of the new version now avialable ...with a few bug fixes ...
Development Version 2.01 (December 2007)
Changes
For Pocket PC's, full screen mode now works on all pages which have a map on the page.
Screen Control now works on all pages except the options and satellite view pages.
If a page file is loaded which is meant for a PDA with a smaller screen, any map windows on the page are expanded until the parameters fill the available area. If there is no map window on the page the parameters are centered on the screen. While this does help the best option still is to design a set of pages to suit the screen size of your PDA using the Settings Manager. This only works with page files created with Version 2.01 of the Settings Manager, if you load them into the Settings Manager and resave they will be ok.
When put into full screen mode (Pocket PC's only) or the Main Toolbar is turned off the pages are also resized if there is a map window on the page.
The OziExplorer.key1 file has been fixed and now contains button defaults for the screen control.
This was in the previous version and wasn't mentioned - the number of loaded waypoints has been increased to 2000 and you can keep loading waypoint files until the limit is reached.
Changes have also been made to the Settings Manager and a new version is available for download.
Many other smaller issues have been fixed.
277479
