Caravan aircon current draw, Kva's required
Submitted: Thursday, Dec 13, 2007 at 22:19
ThreadID: 52538 Views:3538 Replies:6 FollowUps:2
Does anybody have any experience with how much current ie: what size Kva genset i would need to run a herron 3.0 RV aircon system.
Cheers.
Reply By: Member - Olcoolone (S.A) - Friday, Dec 14, 2007 at 07:56
Why not give Air Command a call and ask them...atleast you will get the correct information.
Regards Richard
AnswerID: 276582
Reply By: StephenF10 - Friday, Dec 14, 2007 at 08:13
My Honda EU20 will start and run the Heron 3 in my van. The start-up current is fairly high (>2.5kv) and the Honda stumbles for a second or two but once running it's fine and well within the Honds's rating.
Stephen.
AnswerID: 276583
Follow Up By: Member - Matthew C (WA) - Friday, Dec 14, 2007 at 12:27
So from all this im guessing that a 1Kva honda wont run it at all.???
FollowupID: 540488
Follow Up By: StephenF10 - Friday, Dec 14, 2007 at 19:53
No chance!
Stephen.
FollowupID: 540551
Reply By: Ron173 - Friday, Dec 14, 2007 at 09:16
I run a Truma climaster from my chineese Honda copy 2.8kw gen
AnswerID: 276601
Reply By: Member No 1- Friday, Dec 14, 2007 at 11:28
try getting a soft starter kit for your aircon so as stop ..well lower the inrush start up current
AnswerID: 276612
Reply By: ChrisWA - Friday, Dec 14, 2007 at 12:47
ok this is a good way to work I have a Honda 3KVA they will run 2800kw at 100% now most air con require 1800 to 2000 kw that's 2KVA to start, that is if your air con is an older style with out soft start up . So Now if your looking at getting an air con get good 1 as cheep is not always better, Look at spending at least 2,500 . Same as Gen sets My little Honda Cost a lot almost 4,000 But after 3 years its still go's First pull .
Hope that Helped
Chris
AnswerID: 276627
Reply By: Member - WORM (VIC) - Saturday, Dec 15, 2007 at 11:47
Matt I also have a Heron 3 in my 2006 Expanda. I can start the aircon from my EU20i with the eco throttle off once the compressor has cycled a few time I then drop the gen back to eco throttle and all is okay.
Cheers Worm.
AnswerID: 276762
