LC100 12v adapter in rear
Submitted: Saturday, Dec 15, 2007 at 22:37
shameem
Is the 12v connection in the rear of LC100 adequate to run a Waeco 50L or do I need to install another adapter unit with thicker wiring?
shameem
Reply By: Andrew from Vivid Adventures - Saturday, Dec 15, 2007 at 22:40
No it is not adequate. Yes you do need to install thicker wiring.
Well, depending on how hard and how long you want to run it.
276836
Reply By: Derek from Affordable Batteries & Radiators - Saturday, Dec 15, 2007 at 23:25
Hi Shameem
As Andrew advises no the plug is not suitable.
Yes you need a dedicated cable of 6mm2 and a good socket (Hella Type).
Do you already have a dual battery ?
Derek.
276842
Follow Up By: shameem - Sunday, Dec 16, 2007 at 09:11
Thanks Derek,
I am about to organise a dual battery system. I have the kit from Waeco that comes with thick leads and socket, so it seems it may be best to get all that installed at the same time when I get the dual battery setup.
sa
540733
Follow Up By: Derek from Affordable Batteries & Radiators - Sunday, Dec 16, 2007 at 09:15
No problem that sounds like the way to go.
540736
Reply By: jdbb - Sunday, Dec 16, 2007 at 08:01
Have a look at the RAPS kits on Waecos website.
276859
Follow Up By: Andrew from Vivid Adventures - Sunday, Dec 16, 2007 at 08:38
Or Derek's site... he is an advertiser on this site and helps pay for it - plus he gives excellent service.
540728
Reply By: Member - Kevin J (QLD) - Sunday, Dec 16, 2007 at 08:56
Have been operating a CF 50 from the existing rear power outlet in the LC100 for the past two years without a problem.
The outlet only operates when the ignition is at least on accessories.
I have not operated for any lengthy period without the motor running but in most cases the fridge will hold overnight without any problems.
Kevin J
276866
Follow Up By: Member - Graham H (QLD) - Tuesday, Dec 18, 2007 at 09:35
Have u tried the wire to see how hot it gets when the fridge is running cos its certainly a lot lighter that the recommended wire size.
541101
