Over heating
Submitted: Sunday, Dec 16, 2007 at 15:19
ThreadID: 52597 Views:2069 Replies:5 FollowUps:2
1992 Cruiser for the most part the running temperature is fine but will rise on a long steady climb.Rise and fall is not consistent and when revs drop temp also drops to low.I think the thermostat may be sticking?? It has also been suggested to me this may be a problem with the gauge needing to be caliberated,is this possible...All help appreciated
Reply By: Member - Axle - Sunday, Dec 16, 2007 at 15:51
Capital.
Have had the same problem with a mazda diesel, and landrover defender. Can be a number of things, in my case with the mazda it was the water pump cavitating and creating air pockets in the system, the defender was much the same, getting air in the system thru a bad gasket in the water pump area. could well be the thermostat, go for the easiest thing first .Best of luck ,
Cheers Axle.
AnswerID: 276930
Reply By: Footloose - Sunday, Dec 16, 2007 at 15:54
Sounds very much like viscous fan. If so, it can be re greased easily and cheaply.
Having said that, there are many parts to your cooling system, and each need to be in good shape.
AnswerID: 276933
Reply By: Tim Owen - Sunday, Dec 16, 2007 at 16:11
From memory, the Gregory's manual indicates to check the following things in the following order
1. Thermostat
2. Radiator
3. Fan hub
I had overheating problem in my 92 1hz recently, and by the time i'd replaced the fan hub ($100 part + fitting), had the radiator checked over ($30), and then finally got thermostat checked, and you guessed it - it was the thermostat. Cost $39 replacement for genuine part + fitting. Now the temp hardly moves.
Good luck.
AnswerID: 276936
Follow Up By: age - Sunday, Dec 16, 2007 at 17:27
Tim
You experienced exactly the same as I did with my 90 model 1HZ. Replaced the thermostat with another genuine one and temps started to rise on hills, soft sand etc. Put the original back in and no worries. Replaced fan hub oil at same time and never had another issue.
A
FollowupID: 540802
Follow Up By: Tim Owen - Sunday, Dec 16, 2007 at 21:21
A,
In my case replacing the fan hub did nothing, and the problem was not fixed till the thermostat was replaced (later). Tim
FollowupID: 540864
Reply By: Smudger - Sunday, Dec 16, 2007 at 16:42
Met a fella on the track who'd had an overheating problem in his Land Rover. He put in a new thermostat, replaced hoses, had the radiator re-conditioned, replaced water pump. And it still over heated. So figured it had to be a cracked head, did the job himself. It still overheated. Finally took it to a radiator shop ..the bloke tested the system and said straight off, "You need a new radiator cap mate. I've got one here, $25."
Fixed it.
AnswerID: 276941
Reply By: Member - DOZER- Sunday, Dec 16, 2007 at 16:56
Common fault with your model, get a new fan coupling or put more oil in it..however...one must ask the question...where did the old oil go...and when you answer this, you realise the seals are gone and you need a new hub.
To prove it, install an electric fan up front and turn it on when going up hill...watch temperature decrease and air cond get colder...fix fan and leave electric fan there for the aircond...this is exactly what we did to a friends 1991 1hz 80 std van.
AnswerID: 276942
