Dereks fridge (yes, yet another fridge query)
Submitted: Sunday, Dec 16, 2007 at 20:52
ThreadID: 52608 Views:5749 Replies:7 FollowUps:12
Evening.
What I'm after is feedback on the Sidewinder Fridge sold by ABR.
The good ,the bad, and any other comments.
Has anyone got one?
Yes, Ive read the archives.
Yes I''ve read the web site.
No I don't want to buy a ( insert prefered fridge here).
Not wanting to start a flame war just find some info pertaining to this particular product.
Thanks in advance
And I apologise for yet another fridge post.
Reply By: blue one - Sunday, Dec 16, 2007 at 21:27
They draw 4 amps !!
AnswerID: 276989
Follow Up By: guzzi - Sunday, Dec 16, 2007 at 21:43
When?
The entire time they are running or does it vary as the temps inside reach the set temp?
FollowupID: 540872
Follow Up By: blue one - Monday, Dec 17, 2007 at 06:46
Guzzi,
The elec load will vary depending on access to the fridge, ambient temp etc etc. The thing is, other fridges are far more efficient and draw less current.
Other than that its a good looking fridge.
FollowupID: 540888
Follow Up By: Member - Mainey (wa) - Monday, Dec 17, 2007 at 09:57
guzzi,
Stated simply, "draws" means they 'take' or 'use' 4 Amps, only when they are actually running, from the battery, as an instant number that can be measured and viewed on an ampere gauge, NOT as the usual Amp Hours generally nominated as the 'power use' for a fridge, which will be 2 Amp Hour, based on a very realistic 50% duty cycle based on the high side.
At a realistic 40% duty cycle it will probably equate to a lesser amp hour number than an Engel ??
Which according to blue's "they draw 4 Amps" post would then make them one of, if not the most efficient fridge available.
For a comparison
my fridge draws: ~8 Amps, or ~2.8ah @ ~40% duty cycle, which can be viewed and is fully explained on my Members page!
FollowupID: 540900
Follow Up By: blue one - Monday, Dec 17, 2007 at 17:30
Guzzi,
This may help. Feedback from a 3rd party.
Trol replied:
Hi Rexy,
I have just come back from Kinkuna National Park, just South of Bundaberg. I have a 40 L Engel Fridge/Freezer that I purchased 4 months ago. I have dual batteries and have hooked the fridge into the accessories battery. Some friends that we were camping with had an Engel as well, same capacity, but purchased it some 4 years ago. Still going strong but was draining batteries really fast. The other 4WD had dual batteries as well and was setup identically.
I always take a Volt/Amp Meter with me and we measured the draw from both fridges. Our fridge drew 1.7 amps and the other fridge drew around 4.8 amps, quite a difference. The other fellow had 2 solar panels charging the battery but the best he could get out of the panels was around 6 volts.
We've since found out that Engel have improved the design of the fridges and that the insulation properties are different along with the compressor.
Drawing 1.7amps, I could leave the car without starting it for about 2 1/2 days. Ultimately, the perfect setup would be to have a glind shower that necessitates startup every night for heating water for showers etc. Even with the solar panels and power management system, the batteries in the other car were down to 7 volts within 24 hours. Plus you have the cost of solar panels at approx. $600 a pop. My thought would be to get an economical fridge that draws low amps that cools/freezes economically...
Trol
FollowupID: 540956
Follow Up By: Member - Mainey (wa) - Tuesday, Dec 18, 2007 at 11:46
Blue, how on earth does comparing two similar Engels with totally different power consumption numbers 'help' Guzzi in any way at all, it only adds to the confusion
will it be 1.7 amp or 4.8 amp ?
If it draws 1.7 amps @ 50 d/c = ~20 amps per day.
As Derek has now clarified, your post "they draw 4 Amps" is obviously incorrect.
FollowupID: 541139
Follow Up By: blue one - Tuesday, Dec 18, 2007 at 20:18
seen it all before
FollowupID: 541231
Reply By: Jim from Best Off Road - Sunday, Dec 16, 2007 at 21:27
Derek is a bloke of outstanding integrity.
I doubt you would go wrong buying anything from him.
Search the archives if you doubt me. He's been here for a fair time and I've never heard a bad word.
AnswerID: 276990
Follow Up By: guzzi - Sunday, Dec 16, 2007 at 21:38
I have read of the generally high regard most of the people here hold Derek in.
I too am sure that Derek is a good operator and on the level.
What I don't have is unbiased info on his fridge', thats all Im after.
Not trying to have a go at him or ABR at all.
FollowupID: 540869
Reply By: Doggy Tease - Sunday, Dec 16, 2007 at 22:00
http://www.sidewinder.com.au/page125a.html
his fridge test results are here mate.
One thing about Derek,,,he don't dribble b ullssh it. If you have a question,,either shoot of an e-mail or give him a ring.He backs up what he sells with honesty and integrity as far as i am concerned.
Just a satisfied customer, no affiliation,etc,etc.
meow.
rick
AnswerID: 276996
Follow Up By: Member - Roachie (SA) - Sunday, Dec 16, 2007 at 22:40
I'll 2nd that statement....he backs up what he sells and does a lot of product research before he decides to stock a product.
No affiliation either...just a satisfied customer.....
FollowupID: 540880
Follow Up By: Member - Lionel A (WA) - Monday, Dec 17, 2007 at 09:08
Hey Rick, was wondering where you were, been a bit quiet lately. Pleased to see your still kicking....hahaha.
Hope to catch up down Collie way next month.
Cheers...Lionel.
FollowupID: 540897
Reply By: DIO - Monday, Dec 17, 2007 at 09:25
I have had dealings with Derek. He is a man of his word and nothing seems to be too much trouble for him. The level of service from him was outstanding with fast efficient delivery. I would have no hesitation in dealing with him again. No I haven't purchased a fridge from him.
AnswerID: 277022
Follow Up By: Member - Crazy Dog (QLD) - Monday, Dec 17, 2007 at 12:18
Derek's middle name is INTEGRITY....
Grrr!!!
FollowupID: 540914
Reply By: Member - Troll 81 (QLD) - Monday, Dec 17, 2007 at 09:42
I have one and I have been nothing but very happy with this fridge. Good size fridge and the freezer is is very good as well
AnswerID: 277027
Reply By: TerraFirma - Monday, Dec 17, 2007 at 11:40
Guzzi, Derek has been very helpful to me and he has given me advise to buy other products other than his at times. On the fridge question why is it you are not considering the other main brands.? There must be a reason and curiousity always gets the better of me..?
AnswerID: 277041
Follow Up By: guzzi - Monday, Dec 17, 2007 at 12:46
I am, however the other fridges have been done to death and as such there is a wealth of info out there.
Apart from ABR's web site there is little in the way of feedback/ reviews on ABR's fridge, this is the info Im seeking.
Price, size of fridge compartment , size of freezer, overall external dimensions, power management of ABR's fridge are all attractive and would suit my needs, I'm just trying to find out how those who have one are finding it and from that info how Ill make a decision on how it stacks up to the others in its class for my type of useage.
The other reason is I research things to death before I buy them when big dollars are involved and when you consider the price of a fridge, battery system and a means to keep it all charged its a substancial outlay of $$.
FollowupID: 540917
Follow Up By: TerraFirma - Monday, Dec 17, 2007 at 13:09
Fair enough Guzzi, good answer.. The fridge looks like it's well made a fair alternative to the other brands, 1.2AH average on test looks ok to me, I can't see a mention of warranty..? To me the warranty is critical because your spending $1000.? I like the size of the fridge to.
FollowupID: 540923
Reply By: Derek from Affordable Batteries & Radiators - Monday, Dec 17, 2007 at 16:34
Hi Guys
I was not going to answer and see if the answers arise from owners and other members but must clarify a few things for you.
1) The fridge uses a Italian ACC GD30FDC Brush-less 12v/24v electronically controlled compressor charged with 105g of R134A and start up current is under 3 amps and running amps vary between 2 and 3 amps depending on voltage, temperature, fan etc. The average over 24 hours is around 1.2 to 1.35 amps per hour or a maximum of 30 amps per day. This same compressor is used in the smaller Bushman Fridges that use around 20 amps per day charged with 60g of R134A.
2) Warranty is 12 months on cabinet and 3 years on the compressor.
3) Feedback is available here. Customer Feedback
Note: It does not draw 4 amps !
Derek.
AnswerID: 277079
