cushion washing
Submitted: Monday, Dec 17, 2007 at 10:48
ThreadID: 52617 Views:1550 Replies:3 FollowUps:7
Just wondering if is possiable to gently hand wash cushion covers in our swan outback as the book states not to remove any parts for cleaning.Maybe due to srinkage?Has anyone washed them?
Reply By: Member - DAZA (QLD) - Monday, Dec 17, 2007 at 11:58
Hi Tahlia
A friend of ours cleaned there cushions with a steamer, he didnt
take the covers off, then dried them with a hair drier.
Daza
AnswerID: 277043
Follow Up By: marshall - Sunday, Dec 23, 2007 at 19:08
thanks Steve for the suggestion, yes we will cold wash the dacron/synthetic bedspread and see how it goes...watch this space,,thanks again
FollowupID: 542162
Reply By: Member - Bentaxle - Monday, Dec 17, 2007 at 12:05
Tahlia I was told by an uphostery cleaner that if you wash cushion covers, you can do so by removing the covers washing them and replacing them on the cushions to dry; that way if they do shrink they will only shrink to the cushion size.
Mike
May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
AnswerID: 277044
Reply By: Jim from Best Off Road - Monday, Dec 17, 2007 at 13:11
My philosophy in life is that there always has to be an easier way.
Assuming the cushions are just foam rubber; pick a nice hot day, wash the whole bloody thing without taking the cover off. Take them outside, hose them down to wash out the detergent and leave them in the sun to dry.
AnswerID: 277047
Follow Up By: Member No 1- Monday, Dec 17, 2007 at 16:42
dont like washing eh?
FollowupID: 540949
Follow Up By: Member No 1- Monday, Dec 17, 2007 at 16:43
FollowupID: 540950
Follow Up By: Jim from Best Off Road - Monday, Dec 17, 2007 at 17:20
In a word, no.
It dates back to a technique we developed years ago. We used to camp on a block of land owned by a mate's parents. It had a shed, thunderbox and one of those old concrete wash troughs.
To wash our clothes we used to chuck them in the trough with half a box of Rinso and fill with water. Every now and then we'd give 'em a poke with a stick.
After a day or two we'd hang 'em on the line and hose away the detergent.
FollowupID: 540952
Follow Up By: Steve - Tuesday, Dec 18, 2007 at 21:37
We make removeable covers for lounge suites and have this issue all the time.
I have a Coromal Silhouette and intend washing ours. The "care labels" they put on aren't worth $hyte. They're merely a disclaimer and tell you the most idiot proof way of cleaning them. Upholstery cleaners are only partially successful in that they don't thoroughly do the job. If you was them in cold water with cold water detergent and partially dry them in the shade and then put them back on slightly damp they'll be ok. If you put them back on before they're dry, any shrinkage will not yet have occurred. If they seem tight, just stretch them and stroke them into shape. When they do dry after putting them on, the foam cushion should ensure that they'll shrink no further. Dry in the shade, thus avoiding fading and also avoiding heat which shrinks them. Cold wash, cold rinse, cold dry. There are some fabrics that are not particularly advisable to wash, but most upholstery fabrics are with due care.
FollowupID: 541271
Follow Up By: marshall - Saturday, Dec 22, 2007 at 15:06
washing the covers and then putting them back on the cushions whiledamp seems to work OK for us.
What about washing the bedspread that comes in vans? any suggestions?
FollowupID: 541955
Follow Up By: Steve - Saturday, Dec 22, 2007 at 19:29
depends on filling but if it's feather or feather/mix you've got a bit of a problem. Problem with feather fillings is not so much the feathers themselves but the casing (lining cover) is Japura which is a down-proof material that stops the feathers poking through and eventually making a bit of a mess. If you wash it, you'll wash the down-proofing off and then you'll be spitting feathers....
talking of which, where's my beer?
Most, nowadays are synthetic (dacron/type) filling which you should be able to wash. Again, low temperatures are best.
FollowupID: 541991
