Hilux squeeling
Submitted: Monday, Dec 17, 2007 at 15:36
ThreadID: 52622 Views:3305 Replies:7 FollowUps:8
This will no doubt give great pleasure to the Nissan brigade...
Current model Hilux 3 litre diesel has an intermittent loud squeal from (apparently) front of engine bay at idle. Disappears at revs, but sounds like a big sigh when shutting down...ie it's appears rev related. Doesn't sound like belts, too metallic.
Of course can't replicate at the dealer's...
Any thoughts appreciated.
Reply By: Member - Borgy.. (SA) - Monday, Dec 17, 2007 at 15:42
"This will no doubt give great pleasure to the Nissan brigade..."
Seems to me that you want the "NISSAN BRIGADE" to bite
Cheers.......Dave
AnswerID: 277071
Follow Up By: lakedge - Monday, Dec 17, 2007 at 16:15
Not a bite, just any old mechanics out there may have some ideas. Of course any small pleasure you feel would be a bonus.
Cheers, John.
FollowupID: 540945
Follow Up By: QLD Kev & Darkie - Monday, Dec 17, 2007 at 19:14
Nissan owners would be the only ones able to respond with a probable fix as this is a rare isolated Toyota problem ;)) LOL
Kev
Russell Coight:
FollowupID: 540982
Follow Up By: Kumunara (NT) - Monday, Dec 17, 2007 at 23:54
Kev
Some people at time make some stupid comments.
I have only ever driven a hi-lux on one occasion and that was at work. It was almost new and didn't last one day without spitting out oil and having to have emergency surgery.
Unbreakable - I can't believe that there are people around stupid enough to believe the advertising.
Tjilpi
FollowupID: 541077
Follow Up By: Des Lexic - Tuesday, Dec 18, 2007 at 13:17
Tjilpi, I'm glad that you've had such a perfect run with your Nissans. Didn't you have problems twice going through Alice Springs that required replacement vehicles.
FollowupID: 541162
Follow Up By: Blaze - Tuesday, Dec 18, 2007 at 13:42
Well, Well, Tjilpi.
I think I will let you Yota, Neeesan drivers fight it out, LOL if anyone actually takes the time to have a look at other vehicles there is one that has less problems than both the above and its the good old (Bits are Missan) Mitsubishi.
Major warranty work per 1000 vehicles is 5 percent for Yota, 12.75 percent for Neeesan and 2.3 percent for Mitsi's.
I will keep driving around in my Mitsi, the 3rd I've owned, never been stopped, My biggest warranty claim has been a replacement thermostat... :-)
FollowupID: 541167
Follow Up By: Kumunara (NT) - Tuesday, Dec 18, 2007 at 19:16
Des
Stories get exagerated. I had problems with a blown head gasket. This occurrred after a service where the coolant was replaced and was caused by an air lock due to a mistake by the mechanic.
Rather than be stuck in Alice Springs without a vehicle whilst awaiting repairs my boss decided to upgrade so we could continue on our journey.
Tjilpi
FollowupID: 541221
Follow Up By: Blaze - Wednesday, Dec 19, 2007 at 01:33
Tjilpi, The one you are mentioning is nissan number 2 I believe, the other one that stuffed up you did still drive back to the Riverland before repairs if my memory serves me correctly... LOL
Of course there was also the 4th gear trip to Broome, hehehe
FollowupID: 541335
Reply By: Wayne (NSW) - Monday, Dec 17, 2007 at 17:04
John,
Most 3lt Nissan vehicles would not have that noise because the motor does not run. :-))
If it a metallic sound and is related to revs it might be the harmonic balancer
or the idler bearing on the air con belt adjuster
or alternator bearing
or turbo bearing
Very hard to pick but they would be on top of my list of things to check
Wayne
AnswerID: 277080
Follow Up By: lakedge - Monday, Dec 17, 2007 at 18:16
Thanks Wayne and everyone else,
I think you may be right - two idlers on the serpentine belt that drives everything, plus the clutch on the front of the aircon compressor all could be culprits. It really helps when fronting the dealer to throw in a few tech terms - they treat us like dills otherwise.
Cheers, John.
FollowupID: 540979
Reply By: Member - beachbum - Monday, Dec 17, 2007 at 17:35
Mate I had a similar noise happen with a TD Bravo that i owned for a short period from new. Turned out to be a blown exhaust manifold gasket. Had advice from all and sundry that it was "The Turbo"but a young mech in Darwin picked it first time. Getting it repaired was another story altogether. best of luck.
Ray
AnswerID: 277089
Reply By: Member - Olcoolone (S.A) - Monday, Dec 17, 2007 at 17:35
Spray some CRC onto the belts...not the pulleys and see if it makes a differance.
Regards Richard
AnswerID: 277090
Reply By: TerraFirma - Tuesday, Dec 18, 2007 at 13:04
No problem , just the belts no doubt..! Oh what a feeling..!
AnswerID: 277239
Reply By: Member - Matt (Perth-WA) - Tuesday, Dec 18, 2007 at 15:22
John are you capable of removing the serpentine belt?
If so you can eliminate sooo many possibilities in one quick exercise.
Remove the belt and run for a few minutes...not too long since you water pump and fan will not operate, just long enouoght o ascertain if the problem is and idler or aircon clutch bearing.
You also get to give them all a spin and see how they 'feel'. Another good diagnosis tool is the old LONG handled screwdriver...just cup your fist over the end of the scredriver while holding iut upto your ear and use as a stethescope to hear 'inside' the different bearings.
All the best
Matt.
AnswerID: 277258
Reply By: Kenny Wilson - Wednesday, Dec 19, 2007 at 06:43
Sounds like an air leak, maybe vacuum leak or does that vehicle have a separate air pump,
I've had this problem before in a petrol engine, diesels might be different
AnswerID: 277373
