Mix Battery Types
Submitted: Wednesday, Dec 19, 2007 at 10:32
Firefox
Hi Everyone,
I have 2x 120ah ALCO Batteries.
I am wanting for XMAS to put another 120ah battery into the trailer to increase my power availablity.
(I have decided absoutely NOT to buy a generator or Solar) as this is a more once off trip i am doing.
Can i put a different brand of 120ah battery in (same type) but different brand without any bad impacts?
Thoughts.
Justin
Reply By: Robin Miller - Wednesday, Dec 19, 2007 at 11:20
The short answer is yes Justin with minor side effects but its better to keep the same.
A better answer could be made if you described your charging system .
277397
Follow Up By: Moose - Wednesday, Dec 19, 2007 at 14:17
G'day Robin
Please elaborate for the benefit of one who doesn't understand vehicle electrics very
Surely if I have say a 100ah deep cycle brand X battery it wouldn't matter if a then added a 100ah deep cycle brand Y battery to the system.
Thanks from the Moose
541382
Follow Up By: Robin Miller - Wednesday, Dec 19, 2007 at 14:43
Hi Moose
Can't do you question justice right now as the Xmas 'get it out the door' panic is on but I sure some others can elaborate just as
Just briefly , at least you said both are deep cycles in your question and that is a start.
If you make sure they are both AGM or both calcium or whatever that will also reduce the side effects.
Essentially as the batteries have slightly different voltage and charge requirements you can get one consistent taking more of the charging load than the other which leads to less the max capacity and shorter life.
541383
Follow Up By: Moose - Wednesday, Dec 19, 2007 at 14:55
Thanks Robin.
Was not aware of that. Have always assumed that one brand of, let's say 100ah deep cycle battery, would be the same as another brand. I now know better. Never too old to learn something new:-)
BTW - it wasn't a question specific to my situation - I just used 100ah deep cycle as an example. The original post was a bit confusing because the heading said "mix battery types" but in the body he said "same type" and I was wondering whether you'd misread it. Obviously not - should have known better as I always find your answers to be to the point and "trustable" (unlike some others on here).
The panic will be over soon enough and life can get back to normal for you! Robin - have a safe Christmas break and may 2008 be kind to you.
541385
Follow Up By: Robin Miller - Thursday, Dec 20, 2007 at 11:10
Thanks Moose
Merry Christmas out your way to
Robin Miller
541562
Reply By: Firefox - Wednesday, Dec 19, 2007 at 11:46
hi Robin,
have a pretty fancy charging system with a CTEK 15000 i think it is like the 5 stage charging or something.
The unit is kept permantely connected to the batteries etc.
Justin
277399
Follow Up By: KSV. - Wednesday, Dec 19, 2007 at 11:57
Only problem with CTEK (I have one, great unit) is it only can be fed from mains. Thus invertor required. Tell me it you know other method - I would be very interested.
Serg
541373
Reply By: Member - Mainey (wa) - Wednesday, Dec 19, 2007 at 13:38
Justin, are you going to BUY another 120ah battery ?
or simply 'acquire' another 120ah battery just for this trip ?
As Robin has stated, basically yes, use whatever you want but there are various negatives to using anything but an identical battery, some are so minor you may not know of them.
The cable could be more of a problem than the battery selection ?
277405
Reply By: Mike Harding - Wednesday, Dec 19, 2007 at 13:56
Alco are a distributor not a manufacturer - there is no guarantee that a battery you buy today under the Alco brand will have been made by the same manufacturer who made the one you bought last year but I would hope it has similar specs.
Mike Harding
277408
Reply By: Member - Mike DID - Wednesday, Dec 19, 2007 at 15:43
It's essential that all batteries in parallel have the same charge voltage - the ONLY way to be sure is to check the Manufacturer's battery data sheet - I would never believe the salesman.
E.g. most batteries are charged up to 14.4 volts before switching to Float Voltage (13.6).
If you add a Calcium/Calcium battery (not to be confused with a Lead/Calcium Battery) in parallel, the new battery will not be charged fully because it needs a charger with a higher voltage.
277426
