Gearbox Landcruiser 100
Submitted: Saturday, Dec 22, 2007 at 01:21
ThreadID: 52752 Views:2411 Replies:6 FollowUps:0
Hi all,
Have just test driven a cruiser 100 (1999) which I am considering buying. There is a slight but very audible "crunch" when changing up or down into third gear. When changing down from 4th the noise can be avoided by doing an old fashioned double declutch, which should not be necessary. Have heard a rumour of the lighter Hilux box having been used (desastrously) for a short time in cruisers. Does anyone know about this and whether it applies to this model?
Many thanks, Ian
Reply By: Zodarp - Saturday, Dec 22, 2007 at 05:56
Hi Ianwa
If it has the R150F gearbox beware. Listen for whine on overrun in all gears. If you can get the opportunity, drain the oil and look for evidence of metal.
Regards Zodarp
AnswerID: 277920
Reply By: Member - Phil G (SA) - Saturday, Dec 22, 2007 at 08:27
I think you'll find that all the 100series with the 1Hz diesel had the lighter box. Petrols did not.
If you like the rest of the vehicle, just factor a $3000 repair bill into the cost of the vehicle. Then if you buy it, change the gear oil and see if the crunch goes away.
AnswerID: 277934
Reply By: Goona - Saturday, Dec 22, 2007 at 11:51
Ian,
My mate had the same model with the 1hz motor and the same thing with the 3rd gear of which ended up blowing. Cost him from memory $3500 to fix. Goes good now though.
Goona
AnswerID: 277952
Reply By: trouper - Saturday, Dec 22, 2007 at 14:51
Ianwa,,
Crunching gears and double shuffling......Means Crook Syncro !!!Yep coulpe of thou to fix
AnswerID: 277968
Reply By: Member - Steve NT - Sunday, Dec 23, 2007 at 18:03
Hey Ianwa
The problem here is that who ever serviced it has put thicker oil and not the synthetic oil in it, once this crunching happens it wont stop until it stops.
The thicker oil won't get between the syncro's this is my understanding.
Cheers Steve.
AnswerID: 278138
Reply By: Member - Terry D (QLD) - Sunday, Dec 23, 2007 at 20:23
Hi Ianwa
Goona is about right on the mark for overhaul/replacement - mine went at 160k, cost me $3,450. Was told by gearbox specialist, that from his experience, 150 - 180k's is when these, lighter boxes, give it up.
Good luck
TD
AnswerID: 278165
