Air Bags
Submitted: Saturday, Dec 22, 2007 at 07:16
ThreadID: 52753 Views:2381 Replies:6 FollowUps:4
I am considering fitting air bag suspension to my 80ser. I do not know whether to fit the type that fits in the existing coil springs or going the full hog and fitting the type where the springs are removed. I do realise that there is a difference in price. Your input would be appreciated.
Reply By: Wayne (NSW) - Saturday, Dec 22, 2007 at 07:28
Ray,
I have seen only one vehicle with the springs removed and replaced with air bags and I don't think that it worked that well.
At least if the bags are in the coils and they do happen to have a air leak the coils will keep the back of the vehicle off the ground.
A leak, even a small leak could put the vehicle off the road with no other support for the back of the vehicle.
Wayne
AnswerID: 277927
Reply By: Kiwi & "Mahindra" - Saturday, Dec 22, 2007 at 07:54
Didnt think that you could have airbags without springs....maybe you can hey!
Anyway I wouldnt do it...doesnt sound right.....we just got polyairs fitted to the standard suspension in the navara, we didnt know you could get different ones for different suspension...!! (idiots!!LOL!!)...
Laura
AnswerID: 277929
Follow Up By: Member - Roachie (SA) - Saturday, Dec 22, 2007 at 10:08
G'day Laura,
Yeh, the ones he's referring to are sometimes referred to as "air bellows". They are VERY TOUGH; lots of semi trailers/prime movers etc use them too.
However, as Wayne has stated, if you get a leak in one in the middle of the Canning, there's not much you can do....... not the same as a B-Double on "Sesami Street" (aka Hume Highway), where you can just call up your local fix-er-upper-er and you sweet in an hour or 2!!
Google "Airbagman"......
Roachie
FollowupID: 541914
Reply By: Peter 2 - Saturday, Dec 22, 2007 at 08:46
I'd have thought that it would be hard getting the suspension travel out of the bags compared to coils.
I'm not a fan of changing things from standard. Better off to get the right coils for the job than fitting bandaid approach like polyairs which work fine on the road but will eventually cause grief in continous off road conditions.
Depends I guess on your intended use, if you only want the load carrying capacity once a year then polyairs may be the way to go for your situation.
AnswerID: 277938
Follow Up By: Member - Shane D (QLD) - Saturday, Dec 22, 2007 at 09:41
some comp stuff have big travell as well as the ability to completly drain the compressed side and pump up the "light" side to help give the beast balance in extreme situations
Shane
FollowupID: 541911
Reply By: Crackles - Saturday, Dec 22, 2007 at 08:53
Ray I'd suggest just fitting the Polyairs inside the springs.(On coil sprung vehicles only) They do an excellent job of carrying the additional weight of trailers or extra gear on long trips. The complete air bag replacement is often something that is done in special applications like to lower the car for easy access for aged or disabled persons or occationally used on utes to aid in fitting/removal of campers as well as leveling. The additional cost would be hard to justify for the slight improvement in ride.
Cheers Craig...........
AnswerID: 277939
Reply By: Member - Shane D (QLD) - Saturday, Dec 22, 2007 at 09:00
95% of trucks(rear) and near all buses have airbag only suspension and airbag failures are rare, if they do fail usually its just a valve, however in cruiser I would get springs that are suited to the task you want.
There are many variations of spring rate available and can only cost less than $200 for a pair and are p*ss easy to change( as long as the shock absorber match up), but most of all, are reliable.
There are a few formites that swear by the insert type airbag that can be adjusted to the conditions (load) and are happy with them, there are few that have problems with leaks/blown fittings.
The full airbag (spring removed) are genarally seen on competition vehicles and IMHO wouldn't be suitable for extented use/travell and would also require an air compresser to be running full time
Shane
AnswerID: 277941
Follow Up By: Max - Sydney - Saturday, Dec 22, 2007 at 11:12
Ray - for what its worth I've used Polyairs for 20 years, and am one forumite who swears by them. I find them great for levelling up quickly under varying conditions. Harshest use was on my 80 s where we pulled a camper trailer for about 100 000 k, as well as heavy loaded without trailer up the Canning etc.
Never had a failure and I'd recommend them.
Max
FollowupID: 541929
Follow Up By: DesF - Saturday, Dec 22, 2007 at 17:16
Hi Ray Can only back up what Max has said I have had them on the Pajero ( 5 years) and have done a fair bit of offroad stuff and towed the van a lot, just pump them up when needed and away you go, when empty the ride is same as normal, 5lb minimum and 25lb max, I find 15/18 perfect for bush load or van.
Cheers Des,
ps, I take care where I drive , I have only seen one with a leak ( other than incorrectly fitted) which had a stick in it , he drove over a dead tree, ?????.
FollowupID: 541971
Reply By: normglenda - Saturday, Dec 22, 2007 at 10:16
I have Polyair bags on my 100 Series 2004 Landcruiser. I tow a 2.6 Tonne van and go off road as well. They are great particularly if the optimum pressure is maintained. I had one split around the join last month . Had done about 20,000 kms and 2 years old bag. Poly air sent me a new one.
If you do put airbag only suspension I would carry a spare bag. I was in the transport industry and when airbags did blow it disabled the bus and truck. They did not blow every day but it was often enough
AnswerID: 277946
