changing fuel tank?
Submitted: Friday, Dec 28, 2007 at 10:05
ryno
just put a stick up through my
tank out at a mates place.i know need to change it out it belongs in a triton mk double cab diesel.
anyone got hints and helpful ideas.
Reply By: Member - Graham H (QLD) - Friday, Dec 28, 2007 at 20:31
The nearest wrecker maybe or perhaps a good welder can repair it
278802
Reply By: Gerhardp1 - Friday, Dec 28, 2007 at 20:52
Find a welder to repair it, and maybe consider putting a drain plug where the hole is so you can drain it in future. A wrecker should have a few
old engine sumps that you can cut a suitable piece out of complete with sump plug.
Any muffler
shop welder should be able to handle the job.
Obviously the
tank needs to be removed from the vehicle filled with
water while this is done :)
Or replace it with a long range
tank ?
278807
Reply By: mechpete - Sunday, Dec 30, 2007 at 18:24
If its a standard tin
tank , solder a patch over the hole ,
it will be ok
mechpete
278993
