Which WAECO ???? CF-60 or CF-80
Submitted: Friday, Dec 28, 2007 at 19:29
ThreadID: 52928 Views:8865 Replies:9 FollowUps:18
How you all doing, Having a hard time deciding on which one to purchase. I will be installing it on my flat top tray once canopy goes on so I have the room for either of these, allthough Im a bit concerned about the current draw of the CF-80,big difference compared to the 60.Only reason I like the 80 is because of the seperate freezer compartment, apparently the fride compartment is smaller in the 80 than the 60 because of the freezer compartment. Fridge will be running off a dual battery system.
Cheers.
Reply By: Member - Stephen F (VIC) - Friday, Dec 28, 2007 at 19:48
Another option to consider would be running two fridges, much easier to adjust temps and if you dont req freezer just switch one unit off.Look at this alternative with out the dollar signs if you can afford it.
personally i went an evakool 60l fridge freezer (i like the insulation) and just put two thermostats in one for freezer and one for the fridge.
I personally believe that 80 is to big, but then again how many mouths are you feeding and how much beer do you need to be cold.
Regards.........Stephen.
AnswerID: 278789
Reply By: Pete and Lez - Friday, Dec 28, 2007 at 19:49
Howdy seb,
We have 110 waeco and like you have stated power use is high. We are looking at replacing 110 with a 60 and a 40. Can use both as fridge or freezer or one of each, with both running you are still using only 2/3 of power as the 80, and more versatile set up.
Hope that was of some help.
Peter and Lez
AnswerID: 278790
Follow Up By: Pete and Lez - Friday, Dec 28, 2007 at 19:53
Sorry, was no answer when I replied, but shows it is a better way to go.
FollowupID: 542841
Follow Up By: Member - Stephen F (VIC) - Friday, Dec 28, 2007 at 19:58
I was thinking the same thing, at least there is no double posts.
One other thing is with these big fridges or any for that matter when they get empty the contents rattles around.
To stop this drink a good cask of wine re use the bladder by blowing it up and putting it in the fridge this will stop the contents rolling around.
Cheers.....Stephen
FollowupID: 542843
Follow Up By: Member - Lionel A (WA) - Friday, Dec 28, 2007 at 23:33
Hi Stephen, yep use them bladders all the time. I dont have a fridge yet, but use a 150 lt Extreme ice box. Fill 4 bladders with clean water freeze them before we go away. Top up with ice at the last provisions store before we head off road. This set up not only performs well for over 6 days, the bladders also suply us with cool drinking water.
Cheers...Lionel.
FollowupID: 542892
Follow Up By: seb - Saturday, Dec 29, 2007 at 16:38
Thanks guys, going by the waeco specs the 110 actually draws less than the 80.
FollowupID: 542960
Reply By: Member - Keith C (NSW) - Friday, Dec 28, 2007 at 20:03
G/day seb,I agree with stephan f,we run a 40l engel frig+18l waeco as a dedicated freezer,the 18 holds plenty and only gets opened when needed, it also saves on power because of this and probably together the 40 and the 18 dont take up any more space than the waeco 80
AnswerID: 278796
Reply By: Member - Norm C (QLD) - Friday, Dec 28, 2007 at 20:08
seb, my first comment is that if you have the space and the power to run the bigger one, that's the way I would go.
Having said that, I agree with the others. The initial capital cost of two fridges is higher, but the flexibility you get is worth it in my view if you are a frequent user.
I run a 70 ltr Reefer (of which about 20lt is Freezer) and a 40 ltr Engel. On short trips (a few days), I only take the Reefer. On longer trips (sometimes up to 6 months), I take both. Start out with the Engel as a freezer. Sometimes convert it to fridge after a couple of months when the small Reefer freezer in enough. Sometimes convert it back to (or leave it as) freezer if we are fishing and I want to bring some fish home.
Works for me and from the above posts, others. But initial capital outlay is probably about 50% or so more than one 80 ltr fridge.
All comes down to space, power supply and money. All significant issues in themselves. I suppose another benefit of two fridges is that if one breaks, the trip is not a total loss.
AnswerID: 278798
Follow Up By: seb - Saturday, Dec 29, 2007 at 16:59
Cheers Norm,Thanks for the info.
FollowupID: 542963
Reply By: Axel [ the real one ] - Friday, Dec 28, 2007 at 20:10
Our 80 uses an average of 64amp per 24hrs ,, that is as freezer at -18c and fridge section at +2c and the "dairy" equals +6/7 c ,, when used as all fridge you can add another 25+ amps per 24hrs to the equation ,,may just give you something to think about....
AnswerID: 278799
Follow Up By: Member - Bruce and Anne - Friday, Dec 28, 2007 at 20:41
Hi Axel, sh"t mate what do you leave the lid open all day? I've had an 80 for over 5 years now and done some real time tests and have had it down to 1 aph and a max of 2 aph. I set ours at 5 when we have charge to the battery to it and 3 when not.
Cheers Bruce
FollowupID: 542856
Follow Up By: Axel [ the real one ] - Friday, Dec 28, 2007 at 21:01
Bruce ,have you ever actually put a thermometer in the fridge ?? what do you use to check your amp usage over a 24hr period ?? because tell you right now that the day an 80lt Waeco draws 1-2amps per hr while used as a freezer and fridge I will stand naked in the Queen street mall ,, not in this liftime will a Dannfoss BD50 as used in the 80lt Waeco only use the power you claim , absolutely impossible ,, at your claimed figure it would be using LESS than a 40lt Waeco [ BD35 compressor] and less than any 12vfridge on the market in Australia ,,, Bruce your dreaming.!!!
FollowupID: 542865
Follow Up By: Axel [ the real one ] - Friday, Dec 28, 2007 at 21:21
Just as an adjunct Bruce and Anne , I too have had our Waeco for nearly 5 yrs , use a Steca solar regulator to measure power usage and input , and if you care to have a look about facts and not conjecture go to www.waeco.co.uk/ and scroll down to power usage ,,,,,,,
FollowupID: 542868
Follow Up By: Member - Bruce and Anne - Saturday, Dec 29, 2007 at 10:20
Ok Axel hears what I done, the Waeco 80 was in a house for seven days (moving in) had it running from a 100 amp battery with a 8 amp charger. (do not have a 240 volt converter for the it)
The battery showed 12.2 volts by my multi meter and the charger set to trickle charge (which I believe to be about 2 amps) after seven days the battery showed 13.8 volts this was all while it was running and every thing was frozen in the freezer and ambient temp was 28 to 32 degrees (Nambour in January).
And I have run it for three days without charge on same battery, so go figure. And why do I need to have a thermometer when everything is frozen in the freezer and the beer is nice and cold in the fridge.
Cheers Bruce
FollowupID: 542921
Follow Up By: Axel [ the real one ] - Saturday, Dec 29, 2007 at 12:28
Bruce ,in other words you have not even a 1/2 accurate measurement of amp draw of your waeco and yet you assume an impossibly low figure through voltage measurements over a 7 day period while charging a battery ,, with your method of measurement we could all claim almost zero power/amp draw , thing is its false and totaly wrong.
FollowupID: 542937
Follow Up By: Member - Bruce and Anne - Saturday, Dec 29, 2007 at 12:56
So lets see your saying that the battery charger is putting out more than two amps on trickle charge, and this is not a big charger, and from what you says yours uses 64 amps and 25+ with the freezer on gee my 100 amp battery must be closer to 300 amps have to tell the battery maker about that one. And you have to remember that they don't run 24/7 more like 20 minutes in the hour, so if say someone said it uses 6 amps per hour on a meter than it is only using 2 amps.
FollowupID: 542942
Follow Up By: Axel [ the real one ] - Saturday, Dec 29, 2007 at 13:23
Bruce you obviously cant read or do basic math , read my 1st reply , 64amp on average per 24hrs as FRIDGE + FREEZER ,, add anothe 25+ amps when used as ALL FRIDGE ,, which is almost the same as factory specs , get yourself an amp HR meter not just an amp guage ,,, have alook at www.waeco.co.uk/ and then tell me Im wrong.
FollowupID: 542944
Follow Up By: Jim from Best Off Road - Saturday, Dec 29, 2007 at 13:24
Bruce,
The Undertaker has a most unfortunate way with words but I agree with him on the usage of the 80.
My guess is that when on trickle charge, your 8 amp charger will put out full whack when required and then drop back to trickle when the it senses the batt is near full. I found that a 4 amp charger used in the same way you did would not always keep up with fridge hence my assumption that your's is probably putting in the full 8 amps when required.
Just my thoughts.
Jim.
FollowupID: 542945
Follow Up By: Member - Bruce and Anne - Saturday, Dec 29, 2007 at 15:22
He does have a way with words doesn't Jim, the "Undertaker" hey I'll just call him no I wont go there hahahahaha.
So now I don't known what I am talking about ???? how come my 100 amp battery is not dead after 1.3 days? saying that it uses 64 amps in 24 hours.
ok Iam nearly out of fun time to day but in case you don't like your Waeco Axel cause it uses to much power I'll buy it off you for say 50 bucks
Cheers and all have a Happy and Safe New Year, Bruce
FollowupID: 542954
Follow Up By: Axel [ the real one ] - Saturday, Dec 29, 2007 at 15:37
You still cant do basic math can you Buce ? tis realy time you did some reading on 12v batteries /amps /watts / charging ect as all your replies show that you know jack on the subject ..
FollowupID: 542956
Follow Up By: Mainey (wa) - Saturday, Dec 29, 2007 at 21:52
Bruce and Anne,
You say ""had it running from a 100 amp battery with a 8 Amp charger.
The battery showed 12.2 volts by my multi meter and the charger set to trickle charge, after seven days the battery showed 13.8 volts this was all while it was running and every thing was frozen in the freezer.
And I have run it for three days without charge on same battery, so go figure""
Here is figured:
You have the ability to charge @ 8 Amps and trickle charge too.
The fridge draws less than 8 Amps, (~5 Amps?) so the battery charger will MAINTAIN the battery Voltage at a CONSTANT 13.8 Volts - indefinately.
If you had of checked the battery the day after it was connected to the charger it would have been the same 13.8v from that time on.
To use a battery charger to supply the power to a battery that powers a fridge will give you NO realistic idea of the power consumed by the fridge.
Reason being,
the battery charger is on 24/7 and ALLWAYS delivers whatever the battery requires to maintain it at 100% State of Charge, if it trickle charges @ 2 Amps when battery is fully charged and fridge not running or supplying the full power when the fridge is running (~5 amps) the charger is replacing ALL the power used by the fridge as it's being used.
Hopefully the fridge is off a hell of a lot more than it's on (example, if the relevant numbers are [and we know they are not?] fridge draws 5 amps, runs at 50% Duty Cycle then it uses 2.5 ah)
A battery charger when used this way works similar to a Solar panel, they both deliver the power REQUIRED by the battery to maintain 100% battery SoC and the battery will remain CONSTANTLY "fully charged" (~13.8 Volts in your case) when read while the charger is still attached.
(However a solar panel is only powering the battery during the day and not the night as the battery charger will)
There is no relevance between the Amps going 'in' V the Amps going 'out' when measured with a Multimeter or Amp metre and a Volt metre won't indicate the Amp movements anyway.
Mainey...
FollowupID: 543002
Reply By: MEMBER - Darian (SA) - Saturday, Dec 29, 2007 at 09:47
Hmmmm - If I really needed a freezer and a fridge (I use a Waeco CF 60 now, in fridge mode only) I'd probably get a 40L WELL INSULATED job of some sort (50L Trailblaza maybe ? - incredibly thick insulation up to 125mm walls - no need for silly fridge covers like I have now - $1350 but !) - more insulation should mean less power requirements. Maybe team that with a 40L Waeco for the fridge function .... all up, quite a few $ though.
AnswerID: 278855
Reply By: Member - Mick T (QLD) - Saturday, Dec 29, 2007 at 15:19
Hi Seb,
Mrs Mick T here. We had a Waeco 80ltr & sold it to buy a 40 & 32 ltr Engel. For a family of four this gave us flexibility to store food & the masters grog... I would always go for 2 if you have the room & the $.
Ciao, Chelle
AnswerID: 278878
Follow Up By: seb - Saturday, Dec 29, 2007 at 16:36
Thanks Chelle, what made you decide to sell the waeco & go engel.
FollowupID: 542959
Follow Up By: Member - Mick T (QLD) - Sunday, Dec 30, 2007 at 20:16
Well a number of reasons really. The 80 litre was very big & had trouble circulating air in the back of the cruiser but I didn't feel it kept the food cool enough for all of the different sections. I didn't use the dairy bit at all.. Plus with a family of four, getting into the big one to get drinks etc just meant it had to work all the time.... Our logic was that with 2 smaller fridges we would keep one for food & one for drinks. We spent a long weekend recently on the beach & it was great. We didn't use as much power & the food (& more importantly the beer) was cold & easy to access. Plus with me being on the short side, I didn't have to search as far for the food. Why Engel, my parents had an engel & they haven't had trouble & our Waeco just didn't perform as we had hoped. Hope that helps. Chelle
FollowupID: 543102
Reply By: seb - Saturday, Dec 29, 2007 at 16:33
Thanks for all the info guys, much appreciated, did not mean to start a war either. I probably should have also included in my post that which ever fridge I choose,it will also be my everyday work fridge to keep drinks/food. So in this matter should I consider the CF-60 over the 80. So far Im leaning towards the 60.
AnswerID: 278881
Reply By: Ozboc - Monday, Dec 31, 2007 at 09:40
I have the Cf80 - also running duel battery's (+1 deep cycle in caravan) Very happy with this fridge and have not had the " oh i wish i bought the smaller one - or larger one ) this fridge caters for 2 adults and 4 kids .....
Boc
AnswerID: 279030
