EGT gauge
Submitted: Friday, Jan 04, 2008 at 10:11
Twinkles
Has anyone fitted one to a 3ltr turbo Hilux? Where does it fit and how difficult is it to fit?
Reply By: Kev & Darkie - Friday, Jan 04, 2008 at 11:52
Have you tried to contact Ian from Thermoguard??
His contact details are here
Cheers Kev
| Russell Coight:
279727
Follow Up By: Twinkles - Sunday, Jan 06, 2008 at 07:56
Yes I have emailed him. He responded quickly. I looked at the
beaudesert exhaust I have fitted and it has a bolt where an EGT gauge can be fitted.
544235
Reply By: Member -Signman - Friday, Jan 04, 2008 at 11:59
In the Troopy- I have the pyrometer in the exhaust aft of the turbo. Coz there was a 'plug' (1/4" BSP) already there. Required a 1/8"BSP adaptor to install.
279729
Follow Up By: KiwiAngler - Friday, Jan 04, 2008 at 14:30
I am currently researching the same mod and note this information on the Thermoguard website re installation
Insatllation upstream or downstream???
It apopars that one is better than the other as far as recording the tempetaure at the correct place but on eis easier than the other as far as fitting the sensor.
543898
Follow Up By: Member -Signman - Friday, Jan 04, 2008 at 14:51
In my opinion- the EGT gauge is a 'monitor' only. It's not the type of thing you would look at all day. It just gives an indication of varying exhaust gas temps. under different conditions. I don't think it would matter if it's mounted before or aft of the turbo (even though readings would be different).
Like a barometer at home, I don't look to see the actual pressure- just if there's a rise or fall !!
543901
