Air compressor for the Troopy
Submitted: Friday, Jan 04, 2008 at 12:15
Member - Boo Boo (NT)
A happy and healthy new year too you all.
I am looking at an air compressor for the troopy and have narrowed it down to an ARB $355, big red $? and Max air $? or Blue tongue.
A search of the archives tells me that the above are probably the best and the BT may be better suited for hot climates. I am waiting for a bit more info to come from opplock, but thought i would check with the learned crew on this site as
Boo Boo
Reply By: Member - Coyote (QLD) - Friday, Jan 04, 2008 at 12:31
I have an ARB fitted under the bonnet and although it is reliable, it can be repaired (you can buy spares from ARB) unlike many others where they are practically disposable. The ARB is good for continuous operation but it is not a very high volume compressor, unlike the BT. So if you want to fill big tyres faster, go with the BT or Big red. I am wishing I had bought an endless air, which is basically an airconditioer compressor that runs off the fan belt. a bit more outlay but will fill tyres 10 times faster than any 12V one...
my 2 cents for what it's worth
279736
Reply By: Richard Kovac - Friday, Jan 04, 2008 at 12:33
Boo
I went to buy one of the new ARB compressors at X-mas here in
Perth, the one in the case and on one had any was told 3 months till they are ready to be shipped, and dam it I'm a good impulse buyer too, now will have to wait..
there is an answer in there somewhere
Richard
279737
Follow Up By: Member - Boo Boo (NT) - Friday, Jan 04, 2008 at 12:44
Richard
You should be able to buy one on Monday. All is not lost for an implulse buyer!
Boo
543880
Reply By: itsdave - Friday, Jan 04, 2008 at 12:38
ARB are supposed to be releasing their new one this month after announcing it in one of the fourby mags late last year. Write up was impresive but they had a delay with manufacturing. I am waiting on one to see how good it is
Cheers Dave
279738
Follow Up By: Member - Boo Boo (NT) - Friday, Jan 04, 2008 at 12:41
The
Darwin shop is getting them in on monday so I preume other ARB shops will have them in fairly soon.
Boo
543879
Reply By: Member - Troll 81 (QLD) - Friday, Jan 04, 2008 at 13:10
Boo Boo
I have a ARB one that I mainly use for the lockers. I do pump the tyres up from time to time but they take ages due to the size of the pump. If you are going to be doing allot of pumping then go for something bigger
279743
Follow Up By: Member - Boo Boo (NT) - Friday, Jan 04, 2008 at 13:38
Troll
Thanks for the advise.
Regards Boo
543890
Reply By: Hoyks - Friday, Jan 04, 2008 at 14:01
4x4 Australia had a test in the December mag that was taken out by the new high volume ARB unit.
They are much quicker than the old ones.
279749
Follow Up By: Member - Andrew (QLD) - Friday, Jan 04, 2008 at 16:16
Do you have the specs on the new one readily accessible to compare to the older version?
Some lowlife stole my ARB one from inside the vehicle (in a secure
carpark) a couple of months ago and i only found out AFTER trying to reinflate 4 tyres from 18psi........aaarrgh.
543909
Follow Up By: Hoyks - Friday, Jan 04, 2008 at 18:28
The old ARB one was 36L/minute (no load, numbers from ARB catalogue) and wasn’t included in this test.
Compressor performance figures from 4x4 Australia’s (I assume the L/min is under no load):
ARB High Volume: 75.1L/m 0-30psi 2 min 17 sec. $349
Max air II: 72L/m. 0-30psi 2 min 50 sec. $390
Big Red: 36L/m 0-30psi 3 min 52 sec $399
Blue tongue: 45L/m. 0-30psi 5 min 9 sec. $395
543952
Follow Up By: Member - Andrew (QLD) - Friday, Jan 04, 2008 at 18:35
Thanks Hoyks for that....
543954
Reply By: Member - lyndon K (SA) - Friday, Jan 04, 2008 at 14:10
Have had an ARB compressor for years and am quite happy with it, it is mounted in my Troopy behind the right hand front head light. Neat fit but an absouloute bastard to change globes(as i found out this week!),compressor has to be removed to access globe.
Still happy with it though.
Cheers Lyndon
279750
Reply By: stans truck - Friday, Jan 04, 2008 at 14:19
hI there my son gave me a gift voucher to spent at ARB. i added a few bucks and bought bushranger pro air verry happy with it dont use air that often so i figured that would for me.Must be half ok because you get 5 year warrenty wich is pretty good for $250
279753
Reply By: ross - Friday, Jan 04, 2008 at 15:16
Ive had the Maxair after it look out the honours in some
well published tests in various magazines.
I snapped the plastic filter off but the new ones have an all metal unit
It will pump 4 x 33 in tyres from 17 to 33psi in about 11 mins plus some set up time.
279764
Reply By: Member - Chris R (NSW) - Saturday, Jan 05, 2008 at 09:54
HI Boo Boo
I have 8-10 year old ARB mounted behind driver. Has given good service but noticed a new noise recently.
It pumps at rate of 7lb per minute on skinny tyres between 18 to 50psi. Set your watch by it -
well nearly. I think this is too slow and have envied those who can air up faster.
Made the big mistake of getting the little blue ARB compressor designed for the ARB diff lock. - Should have gone for the full sized new ARB to get better performance - and backup. Much better thinking.
The constant air idea is also appealing.
Best regards
Chris
279886
Follow Up By: Member - Chris R (NSW) - Saturday, Jan 05, 2008 at 09:59
Sorry not entirely clear - when I fitted the ARB difflock last year, I had the option to buy an additional compressor - either another full sized one which could also be used for tyre pumping, or the little blue job which has no other role but to operate the diff lock.
There, that's better.
Chris
544065
