Ride-Right Air Suspension
Submitted: Friday, Jan 04, 2008 at 14:38
Member - lyndon K (SA)
Looking for info in regards to Ride-Rite air
suspension or similar,must be heavy duty.
Have a 78 T/D troopy with Old Man Emu
suspension(as heavy as it gets) 600kg spring pack in the rear + as heavy as they come i the front. Yes,we are over loaded :) as the back is sagging when the Tvan is hooked up, ball weight is around 180 kg,
water tank under car,roller drawers(empty) 150 kg,kaymar duel wheel carrier 150 kg etc etc etc. This is all before we load it! So am hoping air bags at the rear will fix the problem?
Thanks for your help
Lyndon & Bernadette
Reply By: redfive - Friday, Jan 04, 2008 at 20:14
Hi Lyndon
i have airbags on my troopy they work very
well i too have a large spring pack and if you pump them up a little say 30 psi they lift the back just enough too smooth out the ride pump them up and it will take anythink on the back i tow a 1100kg camper about 130kg ball weight no worry sagging email me and ill send you some photos redfive@bigpond.net.au
Glenn
279807
Reply By: Member - John (Vic) - Friday, Jan 04, 2008 at 20:16
Lyndon I have the Firestone bags really very good.
You will find heaps of Troopy owners with them.
279808
Reply By: Member - Leigh (Vic) - Friday, Jan 04, 2008 at 20:51
Hi Lyndon
I followed John's advice and went the same way. Firestone Kit No 2115 will fit with very minor modification and is easy to fit. It has cured what I set out to achieve and it's very simple to achieve the correct ride height under heavy loads. They are cheaper to import than buy here and
places like "Trucksprings" are most helpful. Do a Google and you'll find plenty of suppliers. Good luck!!
279820
Reply By: Richard Kovac - Friday, Jan 04, 2008 at 21:44
Lyndon Hi
I,m with John I fitted the firestone airbags after talking to him about them and they are great, my Troopy is fully loaded all the time and I only run about 20 psi in them and with the CV on about 30 - 40 psi and I have standard
suspension..
Richard
279834
Reply By: Member - lyndon K (SA) - Saturday, Jan 05, 2008 at 09:17
Thanks for the replys,sound just like what i need. Being a lazy bloke i'll probably get them fitted.
Cheers Lyndon
279882
