gas bottle on roof rack
Submitted: Saturday, Jan 05, 2008 at 17:09
steve21
Hi All.
what's the best way of securing a gas bottle to my roof rack, not keen on carrying in back of car.
also my second spare, was thinking of getting some large bolts at bunnings and bolt down, this OK?
thanks steve
Reply By: Member - Stephen F (VIC) - Saturday, Jan 05, 2008 at 17:33
G'day steve
Not too shaw what the correct method of transporting a gas bottles is but like you i've wacked
mine on the roof i've placed the 9kg bottle in a milk create and used 2 tie down straps and it has not gone any where yet.
Cheers.....Stephen
279946
Follow Up By: Ozboc - Monday, Jan 07, 2008 at 21:54
+1
cheapest way - easy to secure - just don't get busted grabbing one from your local
shop ;)
Boc
P.s also try to get one that does not have a "property off XXxxXX "On it
544589
Reply By: Member - Roachie (SA) - Saturday, Jan 05, 2008 at 19:46
Why not just get a proper 9kg LPG bottle holder from a caravan place....the ones they weld onto a caravan's "A" frame. These have an over-centre latch (or some have a long bolt that can be used to tighten the bottle into place).
As for the spare wheel, yes, a 1/2" bolt could be used. You could either weld a suitable nut onto the roof rack and use a length of threaded rod (this would allow you to remove the whole mounting system for when you want to use the rack for something large like a table top) OR you could weld a standard bolt pointing upwards, onto the roofrack, slip the wheel over it and use a large washer and nut etc.
279978
Follow Up By: CLC50 - Saturday, Jan 05, 2008 at 20:14
I carry to 9kg in bottle holders ,bolted to my Rear Tyre Carrier
supported by 100x25mm 6mm thick box Aluminium ,Aluminium 1200 Long go to my rig page & look @ rear shower Pic
544185
Follow Up By: TD100 - Sunday, Jan 06, 2008 at 20:43
i used the 4.5kg holder on my rack and its been half way around oz and its not moved!using the smaller bottle makes it easier to get on and off.cheers Paul
544350
Follow Up By: CLC50 - Sunday, Jan 06, 2008 at 21:04
Sorry I have 2 x 4.5 Kg not 2 x 9 kg & they never move sorry for miss type
544356
Reply By: Member - Coyote (QLD) - Monday, Jan 07, 2008 at 13:24
same as previous post. I chuck it is a old milk crate and use tie downs (not leastic but proper straps with proper locks on them that way it's easy to just release the levers on the straps and bring it down..also tuck in spare tarp or rope etc in beside the bottle as required..
280262
