Candain Seeking Info on 1HD-T Trans
Submitted: Friday, Jun 06, 2003 at 14:13
Dieselcruiserman
Do you guys have a part number on that transmission? I have taken on the task of installing this diesel engine and have run into problems with the transmission.
You guys are so lucky to have as many diesel cruisers as you do, we only had diesels imported into Canada for 8 years.
Thanks Much
Rob
www.raddcruiser.ca
Vancouver Island BC
3RD most beautiful island in the world!!!!!!
Reply By: Member - Wherethehellawi - Friday, Jun 06, 2003 at 18:12
whats the 2nd
Australia is the 1stRichard
21993
Reply By: Bob Y. - Qld - Friday, Jun 06, 2003 at 18:35
Rob,
From my info, tranny model for 1HD-T is H151F. Bit of trivia for you, there are 3 different Synchroniser ring to gear clearances, up to 8/90, 8/90 to 8/92 and 8/92 on.
Transfer cases models are:
Part time 4WD - HF1A
Full Time 4WD - HF2A
Full time 4WD - HF2AV - w/- viscous coupling. Suggests that this latter t/case is fitted to all turbo's after '92, not sure if this correct, as our '97 model has the middle t/case.
What problems are you having with the transmission? Hooroo...
21995
Follow Up By: Dieselcruiserman - Saturday, Jun 07, 2003 at 01:04
I should have specified that we are looking at a auto trans.
Rob
14455
Follow Up By: Bob Y. - Qld - Saturday, Jun 07, 2003 at 07:54
Rob,
The auto model is A442F, 4 speed, electronic shift control, with lock up converter.
Thats about all I've got, unless you need some info on this tranny.
Hooroo...
14459
Follow Up By: Member - Andrew- Monday, Jun 09, 2003 at 08:55
Hi Bob
The VC transfer only ever came with ABS. (to give the
wheels independance for brakes to control.) Dodnt help one bit with drive:-(
14514
Follow Up By: Bob Y. - Qld - Tuesday, Jun 10, 2003 at 21:05
Thanks, Andrew, that explains it. Our vehicle was first purchased in the Isa, and don't think ABS and air bags are
well received up there.
Hooroo...
14631
Reply By: Member - Andrew- Saturday, Jun 07, 2003 at 17:50
Hi There
What year model cruiser do u own??? In America, post 95 came out with a different tranny, same as a Prado here. You have taken on a hard conversion to do, considering, it would be easier to buy a wreck and transplant fuel system including tanks, dash with turbo lights, glow plug system, vacuum from the alt system, will be 24v starter on the motor if japanese, etc.
Best for you to ask the 80 series group in America at www.lcool.org
They might be able to help with the number of someone who imports.......like Christo Slee.
22045
Follow Up By: Dieselcruiserman - Wednesday, Jun 11, 2003 at 05:17
Its a 97 landcruiser, I have been told it runs the smaller tranny. The A442F will be the unit I will need.
Rob
14649
