80 series headlight retaining clip
Submitted: Saturday, Jan 05, 2008 at 22:00
ThreadID: 53150 Views:3345 Replies:3 FollowUps:0
Hello, I would like to replace the headlight bulb in my 80 series & currently I'm struggling with the retaining clip.
Is there anything particular I need to know about getting the bulb out from behind it?
I am not sure if I should unclip it from the top or the bottom, or turn it.
Any advice would be greatly appreciated
Reply By: nowimnumberone - Saturday, Jan 05, 2008 at 22:17
theres usually one end that has a little hook well its like a hook but keeps going till it joins back on to it selfyon it that you usually have to push in towards the globe then slide it over a little hook bit in the actual head light.
good luck
AnswerID: 279992
Reply By: Graham & Lynne - Saturday, Jan 05, 2008 at 22:22
I have 80 series you have to turn circular retainer anti clockwise as viewed from rear
from Graham
AnswerID: 279994
Reply By: x4by4 - Sunday, Jan 06, 2008 at 11:23
Hi Baybreeze,
As Graham said you have to turn it.
It may help if you mark the top of the clip with a felt tip marker so when you are replacing it, you have it orientated correctly as it is hard to see if doing it from the engine compartment
Peter B
AnswerID: 280060
