HF Antenna
Submitted: Sunday, Jan 06, 2008 at 01:52
ThreadID: 53157 Views:13318 Replies:4 FollowUps:18
Can anyone out there advise me the most suitable automatic tuning antenna / aerial for my IC F-7000 hf/uhf/vhf set that I have purchased... I am no a guru so KIS principle needs to apply (Keep It Simple) Cheers
Reply By: Richard Kovac - Sunday, Jan 06, 2008 at 02:24
Recommended option
AT230 AUTOMATIC TUNING ANTENNA
(Moonraker Australia Pty. Limited) 2.6m (8.5ft) length mobile mount whip antenna covers 2–30MHz with automatic tuning function. Continuous CW transmission at high power not guaranteed with AT230.
Richard
AnswerID: 280027
Follow Up By: Member - Mark E (VIC) - Sunday, Jan 06, 2008 at 09:49
I am a long term HF uer and had one of these Moonraker antennas that was supplied with my old Codan 8525, way back in 1985. The thing hardly ever worked properly. I couldn't wait to replace it with the Codan-manufactured 8558 when they came out....even that was a bit marginal after a few years of corrugations, weather and use.
Since about 1993, I have had theCodan 9350 antenna and it has not missed a beat. They are, in my humble opinion the best of the autotuning antennas around (I have also had the Barrett....).Mine has travelled thousands of km of poor corrugated roads, been immersed in rivers in the high country and been out in the weather all those years and still tunes like new.
If you plan on requiring your HF antenna to perform faultlessly whilst travelling in remote areas and you're relying on it for your own and others' safety, don't muck around with anything other that the big brands names...and personally I believe the Codan is the pick of the bunch.
Hope these pics work....
I do also carry a number of emergency antennas, just in case of autotune failure or write-off (NOTHING lasts forever).
The 9350 is reliable, reasonably forgiving with inadequate earthing (though you really SHOULD earth it properly), smaller and less obtrusive than the other types of autotunes and infrequently come up on eBay for reasonable prices, unless you have the $$ to purchase new ($1400 or so).
If you would like more information from a very knowledgable buch of Codan enthusiasts visit:Codan Outback Radio Yahoo Group
Just my thoughts for you and hoping to not start the old Barrett v Codan, Waeco v Engle, Toyota v Nissan debates..........
Good luck with the purchase.
Mark
FollowupID: 544257
Follow Up By: Member - Mike DID - Sunday, Jan 06, 2008 at 10:06
Comparing the 1985 Moonraker with the current model is like comparing the 8558 with the 9350.
FollowupID: 544258
Reply By: Grungle - Sunday, Jan 06, 2008 at 07:49
Is it a IC-F7000 or IC-7000 as they are 2 seperate sets. The IC-F7000 is HF and IC-7000 is amatuer and covers multiple bands. Antenna options are different for both.
David
AnswerID: 280038
Follow Up By: Member - Mike DID - Sunday, Jan 06, 2008 at 10:09
"for my IC F-7000 hf/uhf/vhf set " - this is contradictory.
- the IC7000 is hf/uhf/vhf
- the ICF7000 is HF only
Which one have you got ?
FollowupID: 544259
Reply By: Member - Olcoolone (S.A) - Sunday, Jan 06, 2008 at 10:14
WMS as David said is it a IC-7000 or a IC-F7000, if it is a IC-7000 that does HF/VHF/UHF you can't put a autotune antenna on it very easy and why did you buy this radio.
We use and have a few IC-F7000 HF radio's that you can use on the VKS 737 network, if you want a autotune antenna for this radio you can use a Codan 9350 or Barrett 910 but you have to use a converter box that you can get from Icom for about $150.00.
Or you can use the Moonraker autotune that is sold for that radio and plugs directly into the back.
I have a near new autotune Moonraker for sale if you want one.
But what radio is it first.
Regards Richard
AnswerID: 280052
Reply By: WMS - Sunday, Jan 06, 2008 at 10:29
Rightyoooo guys thanks a lots for the feedback and good question raised re: f7000 or 7000.. confusion is because I am in PNG where i live n work & unit in Brisbane where I am about to fit it into my Pajero so couldn't quickly look... been on the web and viewed pic's and it is definitely an Icom 7000... which is just HF right?
So we are back to which antenna (auto tune preferred) so I guess Moonraker, Codan or Barrett? I bought the unit off EBAY new and no little about them / it but am planning some big trips so needed one.
Can anyone tell me a bit about this set... good, bad, very capable,just oK or different etc... then... which antenna best and will work well n get all the channels (price is important if no extra benefit is derived.. dont wanna just pay 4 a name)
Thanks for help to my simple queries...
Mike
AnswerID: 280054
Follow Up By: WMS - Sunday, Jan 06, 2008 at 10:37
Thanks Richard n others... I have bought the wrong set it seems... dont want / need multi band... will flog it I think, buy a stand alone HF set and autotune antenna... problem solved unless I can get an autune which it seems I cant...
FollowupID: 544265
Follow Up By: Mike Harding - Sunday, Jan 06, 2008 at 10:46
Take a look here:
Screwdriver mobile antannas
Mike Harding
FollowupID: 544268
Follow Up By: WMS - Sunday, Jan 06, 2008 at 10:47
Can anyone therefore suggest a good HF Set that is compact and not 'shoebox' size and can be mounted neatly with Autotune arial... I guess we are talking Codan / Barret ?? what are the best models?
FollowupID: 544270
Follow Up By: Mike Harding - Sunday, Jan 06, 2008 at 10:49
Hmmmm.... the link doesn't go directly to the page I intended.
From the above page click on - "Amateur and CB antennas"
then click on - "High Sierra antennas".
The two antennas there should do what you seek.
Mike Harding
FollowupID: 544272
Follow Up By: Mike Harding - Sunday, Jan 06, 2008 at 10:52
PS. With that radio you might consider going for a Amateur Radio Licence would give you _lots_ more capability the simply VKS737. The new Foundation Licence is not hard to obtain:
FollowupID: 544274
Follow Up By: Mike Harding - Sunday, Jan 06, 2008 at 10:53
It's not my day! :)
Foundation Licence
FollowupID: 544275
Follow Up By: WMS - Sunday, Jan 06, 2008 at 11:19
Thanks Mike... its not... can open "Foundation Licence" link...
Are you suggesting I can get an Autotune Antenna for the Icom 7000 that will give me true and full HF capability ?
Mike
FollowupID: 544277
Follow Up By: Mike Harding - Sunday, Jan 06, 2008 at 11:39
Told you it wasn't my day :)
WIA
try there and follow the links.
I think either of the two antennas on the Andrews website (above link) will do what you need.
Mike Harding
FollowupID: 544279
Follow Up By: Member - Mike DID - Sunday, Jan 06, 2008 at 11:54
"... I have bought the wrong set it seems..."
. . . also are you aware that IC7000 doesn't have Selcal and Telcal capability for the VKS737 network or Emergency Call for RFDS ? And that it's illegal to use the IC7000 on VKS737 or RFDS frequencies ?.
FollowupID: 544281
Follow Up By: SNAKE No1 - Monday, Jan 07, 2008 at 01:34
Hi WMS,
I have a High Sierra 1800 Pro (Screwdriver Antenna) and it is a magic bit of gear.Lee Andrews in Sydney sells them ,not cheap $1000 but in my opinion worth it.Will tune from 3Mhz to 56Mhz at 1Kilowatt if you so desire.(no doubt Ill get hung for the 1Kw).Cheers Snake
FollowupID: 544418
Follow Up By: WMS - Monday, Jan 07, 2008 at 08:09
Snake, is what you have on a multiband Icom 7000 also? If so,does that mean it automaticlly tunes all VHF, UHF & VHF channels?
FollowupID: 544433
Follow Up By: Member - Raoul (Snake) H (QLD) - Monday, Jan 07, 2008 at 21:15
Hi Mate,
I run an Icom IC737 Hf Radio(oldie but a goodie)it has an auto tuner in it.I also have a Kenwood TS480 HX in the Vehicle.The both radios are Amateur Radios.The 737 can TX from 1.8Mhz to 29Mhz and the 480 from 1.8 Mhz to 56Mhz.The High Sierra is motor driven either up or down(in or out) with a control switch mounted in the car,also available is an auto tuner to suit the antenna but I have no use for one as the Kenwood has inbuilt VSWR meter an I can tune any freq.with it by first tuning to maximum noise and fine tune with the meter.I wont comment on type approved radios except to say it is a load of crap but the laws must be adhered to.The IC7000 is a magic radio and will TX on just about everywhere it listens but this needs modifying the rig and possible legal problems.As someone has already posted the Amateur Foundation Licence is an easy test and after passing the Icom or any other Amateur Radio becomes legal for you to use(on the Amateur Bands only) I cannot spell it out any better than this.I hope I havent bored you too much. Cheers Snake
FollowupID: 544568
Follow Up By: Member - Raoul (Snake) H (QLD) - Tuesday, Jan 08, 2008 at 00:55
Hi Again,
To give you a better idea of frequency and wavelength go to your local Dick Smith store and pick up their Annual Catallogue turn to page 362,will give you a bit of an idea.Also look around your local area see if you can find an Amateur Radio Operater,he or she will be only too happy to show you their station and give you a hands on intro to radio and how to use a radio.Feel free to ask any questions of myself or the other Amateur operators on this site. Cheers Snake
FollowupID: 544621
Follow Up By: Member - Mike DID - Tuesday, Jan 08, 2008 at 07:51
"The 737 can TX from 1.8Mhz to 29Mhz and the 480 from 1.8 Mhz to 56Mhz.
The IC7000 is a magic radio and will TX on just about everywhere it listens but this needs modifying the rig and possible legal problems."
- Didn't you have to modify the the IC737 and the TS480 to Tx everywhere outside the Amateur bands ?
FollowupID: 544636
Follow Up By: Member - Raoul (Snake) H (QLD) - Tuesday, Jan 08, 2008 at 21:24
Hi Mike R, No 1.The legal problems I refer to are if you transmit outside the Amateur Bands with a non type approved radio you can be in breach of the regulations.You can however use commercial radios,eg Codan,Barrett etc on Amateur bands.
No2 It is not illegal to modify a radio to have the capability to TX anywhere,but if you do TX that is when you are liable to have problems.The reason I posted in the first instance was to offer advice to a fellow forumite so I end my involvement in the discussion with this follow up.
Cheers Snake
FollowupID: 544753
