Bushman Max-Air air compressor
Submitted: Monday, Jan 07, 2008 at 16:06
Member - Bushpig
Just a silly question but can you leave the compressor running as you go from wheel to wheel or do you have to turn it off after pumping up tyres?
I usually turn it off but it is a bit of a pain switching on and off all the time. Just wondering what you all do.
jack
Reply By: Member - Troll 81 (QLD) - Monday, Jan 07, 2008 at 16:10
I leave
mine on
280288
Reply By: Member - Bucky (VIC) - Monday, Jan 07, 2008 at 16:17
Jack
My Big Red Series 2 runs till all 4 tyres are up to the desired pressure.
There is no load on the motor, till it has to push against pressure.
Bucky
280289
Jack
Bucky
280290
Reply By: ross - Monday, Jan 07, 2008 at 19:05
It is a pain switching it off. Because the Maxair have a decent length of electrical cable ,I take the compressor to the tyre.
Leaving it running wont hurt,probably cools it down if anything
280324
Reply By: Member - Luke (SA) - Monday, Jan 07, 2008 at 22:57
Leave it running
280394
Reply By: Dave from P7OFFROAD Accredited Driver Training - Monday, Jan 07, 2008 at 23:01
leave it running
or go one better and fit a small
tank (with a pressure switch of course), and a shut off valve, then the longer it takes you to put caps on and off, the more pressure in the
tank, and the less time to fill your tyres...
or you could just leave it running ;p
280396
Reply By: Member - Bushpig - Wednesday, Jan 09, 2008 at 12:50
Thanks guys.
jack
280583
