jacyco swan
Submitted: Tuesday, Jan 08, 2008 at 09:47
tahlia
We have a jacyo swan outback that is only 12 months old the
water push pump tap jams when trying to pump
water.Has anyone else had trouble with these?
Reply By: Jim from Best Off Road - Tuesday, Jan 08, 2008 at 09:53
Simple fix, pull the top off the pump, you shouldn't need to take the whole thing out. Just grab the top firmly, give a good twist and tug, the handle and plunger should pop out.
On the end of the plunger is a washer. Rub a bit of vaseline around it and replace. You need to this every so often to keep it lubricated.
Jim.
280427
Follow Up By: DIO - Tuesday, Jan 08, 2008 at 18:46
I found that any vegetable (based) oil is better than vaseline. No residual taste.
544720
