external showers
Submitted: Wednesday, Jan 09, 2008 at 09:27
Jodi
Can someone please explain how an external shower works on a caravan. What are the advantages and disadvantages compared to an internal setup. Are they ok for toddlers and babies ?.
Reply By: Member - barbara M (NSW) - Wednesday, Jan 09, 2008 at 10:17
Hi Jodi,
I am not sure how exactly they work but I can tell you how they appear to. You have a little compartment on the outside of your van 12 inches by 10 inches approximately by 6iches deep it has a lock and key you unlock it the door drops down and inside it is a hot and cold tap and a hose with a shower rose on the end (we chandged the hose from plastic to metal) it has a button thing on the end near the rose so that once you get the temp right you just push it to stop the
water flow to conserve
water we wet down turn the
water off and soap up then turn the
water back on to hose off. It just like a shower at home we have used it with littlies. To get the
water hot about 5 minutes before your shower turn like a light switch on inside your van to turn the hot
water system on. The hot
water system on our van is stored under a
seat.
Advantages: Doesnt take valuable space up inside your van you get to have a shower outside under the stars in pop up shower tent heaps cheaper.
Disadvantages: If it is raining it is a bugger then you just have a wash out of oa dish.
If you decide this is the way to go just check that the shower is on the side of the van the door is not as all that
water will wet the area under your awning.
PS we stand on a rubber door mat so our feet wont get wet
Barb
280564
Follow Up By: Member - John T (NSW) - Wednesday, Jan 09, 2008 at 12:46
Hi Barb,
Just cannot help myself here - that rubber mat must be very impressive cos it can stop ya feet getting wet under the shower hehehe.
| John T (Lifetime Member)
VKS-737 Mobile 2619
Selcall 2619
"Argue for your limitations and sure enough they're yours" - Richard Bach in "Illusions" Lifetime Member My Profile My Blog Send Message |
544824
Follow Up By: Member - barbara M (NSW) - Wednesday, Jan 09, 2008 at 13:01
HI John,
Good one got me there I cant help it if I am a bit slow. Obviously a blonde moment or Red in my case
Barb
544828
Follow Up By: Member -Dodger - Wednesday, Jan 09, 2008 at 17:44
Everything Barb Has said is spot on.
We made an ensuite out of some canvas material that attaches to the van via a sail runner ( read awning runner) and have a porta potti that goes in and the enclosure acts as a loo and a shower.
As barb says we just turn on the gas hit the switch inside the van and the hot
water is on tap within 20minutes or so. All is controlled by the onboard sensor which turns off when the
water is at the set tenp IE fully auto. Great Idea.
544896
Follow Up By: didiaust - Wednesday, Jan 09, 2008 at 18:05
We use a seperate shower - small gas unit and nylon ensuite. We place it at the back on the annex - right at the back door and stand in a large plastic dish so that we don't have a mud mess. The
water then is good to put out the fire- is also good to soak the feet each night as they tend to get
camp grotty if you don't wear enclosed shoes
544902
Reply By:- Wednesday, Jan 09, 2008 at 19:29
"Can someone please explain how an external shower works on a caravan"
G'Day,
Most vans are fitted with a small hot
water storage heater, just a smaller version of the one at home. Ours holds 5 litres.
They are usually both gas and 240Volt, when you press the button the light for either gas or 240V, when powered, turns on.
From there a pressure pump takes the
water to tap, shower, whatever you have.
Inside or outside is no different in operation, except of course that you are either inside or outside. :)
Rolande
280646
Reply By: Bonz (Vic) - Wednesday, Jan 09, 2008 at 21:01
I am one that really doesn't understand the wonder of a shower when
camping out. I like a wash and cleanup but hmm a shower is such a big
water use and I just don't see the value....
OK OK OK I have just booked a camper for 12 days in NZ with an INSIDE loo and shower
Now when we retrun will be better positioned to say what a shower is great for.
280675
