buying an 80
Submitted: Thursday, Jan 10, 2008 at 22:18
breedy
hi all,what a great site to stumble across,hope someone can help us out a bit,in the near future will be looking at buying a petrol automatic 96/97 80 series,what are approx figures for major 100 000/200 000
services and what's involved??timeing belts etc
thanks
Reply By: Member - Phil G (SA) - Friday, Jan 11, 2008 at 09:03
No timing belts to change (its chain driven).
Standard servicing for a petrol motor - filters are relatively cheap.
Valve clearances are a shim adjustment - need to be checked every 40k if you're running on gas - 80k on ULP.
Big servicing costs are the wheel bearings (4
wheels), swivel hubs and diff/gear oil changes, so the big
services do cost a lot, and take a lot of time.
280924
Follow Up By: breedy - Friday, Jan 11, 2008 at 22:00
thanks phil,that sounds a bit cheaper than the pajero,belts,
water pump,idlers.$1000uh!time to upgrade,thanks
545422
Reply By: Ralph C - Saturday, Jan 12, 2008 at 12:07
Having owned a Petrol manual and now Turbo Diesel Auto I would agree with other feedback.
Tojo parts even non genuine are expensive but hopefully not often required.
It is critical to find a mechanic who knows how to tension wheel bearings. We are in the tribunal next fortnight after a mechanic ruined our front hubs (and nearly our lives) after less than 10,000 kilometres! Insist on new locking tabs being fitted each time they are dismantled. Supply your own and ask to see the old ones.
Our lengthy experience in extreme four wheel driving (most recently in the
Vic high country with day time temps above 40 degrees) suggests 80 series outlast and out perform newer models of Nissan and even 100 series petrol.
281181
