Ernest Giles Road to Hermannsburg
Submitted: Friday, Jan 11, 2008 at 14:45
ThreadID: 53348 Views:5993 Replies:9 FollowUps:4
Hi Can anyone tell me if the Ernest Giles Road from the turnoff on raod to King Canyon to Hermannsburg in NT is driveable by 4wd and camper? PoppyG
Reply By: Vince NSW - Friday, Jan 11, 2008 at 14:52
Yes. It was not good last time we used it, but quite drivable with lots of corrugations.
Vince
AnswerID: 280995
Follow Up By: PoppyG - Friday, Jan 11, 2008 at 14:58
Someone said the track is not well marked and the terrain changes with the weather. If we could go from Yulara to Hermannsburg via EG rd, I am told it would save about 500km by not having to go on the Meenerie Loop Road, PoppyG
FollowupID: 545327
Follow Up By: Vince NSW - Friday, Jan 11, 2008 at 15:09
It's a lot shorter but not that mush quicker due to the need for SLOW driving over some of the bad sections. If time is not an issue, I would take the Meenerie Loop as there is more to see & do.
Vince
FollowupID: 545330
Follow Up By: Willem - Friday, Jan 11, 2008 at 15:14
Hmmm PoppyG...
Not sure who your informant is or exactly which route you are proposing.
From where you meet the EGR....to the west via Mereenie Loop Road is 400km and east via Alice Springs is 355km.....So a saving of 45km
Or are you talking about driving up the Finke River Track past Boggy Hole to Hermannsburg?
FollowupID: 545333
Reply By: Voxson - Friday, Jan 11, 2008 at 15:06
Rough as guts last time i used it.
We struggled in places to stay on track because of unmarked roads.
If you have oziexplorer you will find it easy.
AnswerID: 280996
Reply By: PoppyG - Friday, Jan 11, 2008 at 15:16
Soory - I meant driving up the Finke River Track past Boggy Hole to Hermannsburg. I'm not familar with area but learning fast. PoppyG
AnswerID: 280999
Follow Up By: Willem - Friday, Jan 11, 2008 at 15:27
Thats better. Now we know what you are talking about.
The first part of the Finke Track is OK. Once you start crossing over the dry(or wet) riverbed things get a little more interesting.
It is more than likely that you will scratch your vehicle and camper on overhanging branches. Then you have to ascertain whether you can make it through the waterhole just past Boggy Hole. Should you be successfiul with that you will need to drop your tyre pressures even further to get up the Finke River and in to Ellery Creek. The track is doable but more suited to experienced 4wd travellers. I would ring NT Parks and Wildlife(or whatever they are called now) to ascertain if you will be able to get through the Finke at Boggy Hole.
FollowupID: 545336
Reply By: MEMBER - Darian (SA) - Friday, Jan 11, 2008 at 15:46
Yes and no - all depends on prevailing conditions - you need to check with the locals as mentioned above - we did the Finke Gorge with trailers 2 years back - a great drive then - no water at all to cross, but at times people often have several wet sections to traverse - as Willem suggests, you need to be accomplished with tyour hardware in very soft sand - coming from the west, we had to cross the dry Palmer river and then the various sandy sections of the Finke - it was very dry and powdery sand for us - with very low tyre pressures including the trailer, it was ok.
AnswerID: 281005
Reply By: PoppyG - Friday, Jan 11, 2008 at 15:56
It sounds like a challenge and one that we may probably take after a bit more research and a check with the locals before we arrive. We are going with a mate so between the 4 of us, we should be able to negotiate the tricky bits...famous last words....!!!!! Expect to be there at the end of May and will be coming from the west via Great Central Rd. PoppyG
AnswerID: 281008
Reply By: Steve63 - Friday, Jan 11, 2008 at 16:05
The Ernest Giles road is a formed drit road. It has the usual hazards (holes, rocks and corragations). Last time I was there it was in reasonable nick. Be aware that peoples opinions vary depending on there experience. I had some one tell me the Mereenie Loop road was in bad condition. We drove it and it was the best I had ever seen it. I can't see why you would not be able to take a 4wd camper along there. If you mean the track into Boggy Hole that is a whole differnt story and caution should be used on that track. If you want a take a camper along there a second vehicle would be strongly recommended. Some of the sand is very soft and if it has rained recently the whole track along the Finike enters a new world. You may then be in full path finding mode and a few days (or longer) will need to be added to the travel time. The southern entrance is not well marked. It is not always well travelled. We stayed at running waters a few days and Boggy Hole a day or so and only saw 3 other vehicles.
Have a good trip.
Steve
AnswerID: 281011
Reply By: mfewster - Friday, Jan 11, 2008 at 16:40
If you are going to do the Boggy Creek Track, particularly if inexperienced adn with a camper, make sure the Rangers know when you are going through and arrange to notify them when you are through. As everyone has noted, very easy to get caught on that track, especially over summer. It can be quite some time before someone else comes along.
AnswerID: 281019
Reply By: rosgeog - Friday, Jan 11, 2008 at 17:46
PoppyG,
I would ask the question closer to the time you are travelling. If we have any rain up here the Boggy Hole track takes on a different character. Currently after ten days of 40+ the sand will be very dry and very soft. We have done that track a few times and it is enjoyable. As noted you will be with other vehicles and that is the best way. We have had some terribly prepared tourists that have got themselves lost/bogged and it is an extremely expensive recovery. Over 100k from Alice.
Take Care
Ross
AnswerID: 281032
Reply By: PoppyG - Friday, Jan 11, 2008 at 17:49
Thanks for all the good advice. I still have a lot of planning to do and will take into account what everyone has said before I make the final decision. cheers PoppyG
AnswerID: 281035
