Loading pics from members gallery
Submitted: Friday, Jan 11, 2008 at 22:37
ThreadID: 53372 Views:2305 Replies:4 FollowUps:8
Hi all, I cant seem to load a gallery pic to put on a forum posting anymore?? What am I doing wrong, any ideas? Thanks unc
Reply By: ExplorOz Team - David - Friday, Jan 11, 2008 at 22:59
Uncle,
There was a small scripting error - I have found and fixed it.
!MPG:10!
AnswerID: 281115
Reply By: Bware (Tweed Valley) - Saturday, Jan 12, 2008 at 00:30
I have had the same problem but now,
!MPG:39!
AnswerID: 281123
Follow Up By: Bware (Tweed Valley) - Saturday, Jan 12, 2008 at 00:32
Right
!MPG:39!
FollowupID: 545450
Follow Up By: Bware (Tweed Valley) - Saturday, Jan 12, 2008 at 00:35
Checking
FollowupID: 545451
Follow Up By: Bware (Tweed Valley) - Saturday, Jan 12, 2008 at 01:04
Uncle,
My first follow-up was the easiest way to do it; click 'members gallery' and click on the photo then close the window and then hit preview to check that the image is there.
My second follow-up is larger. It requires opening a new web-browser window, going in to your 'my home' page, click the photo you want so that it is viewed larger, right click on it and select 'copy image location' then go back to your other open window (with the post you want the picture in) and select 'insert image' then a box will come up. The first thing you do is delete the 'http' which is in the box because the image location you are going to post there has already got that. Right click in the box and select 'paste' and the image location will be there. Click 'insert'. Make sure you do this on the next line if you have any text before it. eg
Down here.
Otherwise the image will start from the end of your last line and overlap the advertising on the right.
There probably are other ways to do it but the trouble is that there is no guide. The simple way gives a small picture which makes it harder to see any detail in the image.
FollowupID: 545455
Follow Up By: Bware (Tweed Valley) - Saturday, Jan 12, 2008 at 01:08
In my original reply I ended up with a thumbnail of the photo as well; ask me how I did that LOL
FollowupID: 545456
Follow Up By: Bonz (Vic) - Saturday, Jan 12, 2008 at 08:38
wow thats a lot of water damage where is it??
FollowupID: 545477
Follow Up By: Bware (Tweed Valley) - Saturday, Jan 12, 2008 at 09:30
Hey Bonz, they looks just like a photo I took LOL
The photos were taken last Saturday around Murwillumbah. We had a little bit of rain last Friday. I bet you could use some down that way.
FollowupID: 545486
Follow Up By: Bonz (Vic) - Saturday, Jan 12, 2008 at 15:45
I liked the power lines in the pic!
Yep we sure could use a little around these climes.
FollowupID: 545550
Reply By: equinox - Saturday, Jan 12, 2008 at 00:44
kewl
!MPG:20!
AnswerID: 281126
Follow Up By: Bonz (Vic) - Saturday, Jan 12, 2008 at 08:36
works a treat
FollowupID: 545476
Reply By: Member - Uncle (NSW) - Saturday, Jan 12, 2008 at 07:31
Many thanks guys I'll give it a try now.!MPG:107!
AnswerID: 281135
