pressure cleaners
Submitted: Sunday, Jan 13, 2008 at 09:13
ThreadID: 53416 Views:2400 Replies:6 FollowUps:5
After spending time at the top end for a period of time we are contemplating to buy a pressure cleaner to rid the under carriage of the red tinge what to buy petrol or electrical. We are looking at about 2000 PSI any help or experience would be highly appreciated
Rev's
Reply By: Member - andrew B (Kununurra) - Sunday, Jan 13, 2008 at 09:44
Gday Rev's
Santa got me a Ryobi one, seems pretty good so far, but haven't given it a good test on the car as yet. It took the oxidisation off the colorbond fence pretty well, and took the old paving paint off the concrete relatively easily. Car paint seems to be a lot tougher so should be able to handle the pressure.
Cheers Andrew
AnswerID: 281320
Follow Up By: REV'S - Sunday, Jan 13, 2008 at 11:43
Is the Ryobi Electrical or petrol
Thanks Andrew
FollowupID: 545707
Follow Up By: Member - andrew B (Kununurra) - Sunday, Jan 13, 2008 at 11:59
Sorry....electric. in many ways I would prefer a petrol, but a bit pricey unles you get the cheapie 2 stroke, which may be ok for the amount of use they get. Santa wasn't sure of my preferances. I do prefer to keep the electricity away from water....
Cheers Andrew
FollowupID: 545710
Reply By: cackles - Sunday, Jan 13, 2008 at 11:01
We bought a karcher years ago and it works a treat, however we did have it in for repairs not long after we bought it.
Turns out they don't cope well on an extension lead, something to do with power loss due to the length of the lead.
Interesting to note that karchers are now made with with plastic componentry, not metal anymore.
cackles
AnswerID: 281343
Reply By: _gmd_pps - Sunday, Jan 13, 2008 at 12:51
I have a Briggs & Stratton Petrol one 2700psi.
Don't buy one of these cheap Scorpion Petrol ones ..
the pump is not up to scratch and it will not last.
they are cheap Chinese knock offs and they did not yet
get the pump right.
I had those smaller toy ones before but it just is not the same.
I can remove motor and pump from the trolley and mount it
on the boat trailer to take it with me.
good luck
gmd
AnswerID: 281366
Follow Up By: REV'S - Sunday, Jan 13, 2008 at 14:51
Thanks for the advise Ill look into it
Revs
FollowupID: 545725
Reply By: troopyman - Sunday, Jan 13, 2008 at 14:11
gerni
Forget the rest .
AnswerID: 281375
Follow Up By: Ozboc - Sunday, Jan 13, 2008 at 22:40
NOt the best, and you only say that if you have a vested interest ...
avoid if possible and go the cheaper option - you get more bang for your buck ...
any Italian machines. .. yes .... German yes ..
Boc
P.s yes i used to work for Gerni ( powerclean - viking equipment what ever you want to call them )
FollowupID: 545803
Reply By: DIO - Sunday, Jan 13, 2008 at 15:00
Have used a Karcher for about 7 years. No problems, does everytning I ask of it. B E W A R E thought of placing a high pressure jet of water too close to steering joints, bearing seals, plastic trim, window trims/rubbers, or any place high pressure water might get under and efficiently lift off/remove trim/fixings etc. My handbook also advises NOT to place the jet of water (near the nozzle) directly onto the tyres. Something to do with breaking down the structure of the tyre or similar. Go for electric. No unecessary engine noise, smell, hard starting, regular servicing etc.
AnswerID: 281381
Follow Up By: REV'S - Monday, Jan 14, 2008 at 07:09
Thanks for the advice. What PSI doe's it put out And doe's it come with plastic or brass hose connection fittings.
Regards Allan
FollowupID: 545816
Reply By: Peter 2 - Sunday, Jan 13, 2008 at 18:50
Second the Gerni if you want something that will last.The better ones have a bronze pump (plastic ones warp with the heat and use, alloy ones corrode and also warp with the heat).
The one I've got is the little one and is branded as a Nilfisk but has Gerni all over the innards and the booklet.
AnswerID: 281429
