Headlamp 80 series
Submitted: Sunday, Jan 13, 2008 at 13:35
BayBreeze
Is there anything else I can test or replace to get my driver side headlamp working?
It's not the fuse & it probably is not the bulb as it works OK when high beam is turned on.
It came on OK once when I was trouble shooting so it might be working intermittently
Reply By: age - Sunday, Jan 13, 2008 at 13:41
BayBreeze
I had a similar problem with my 80 series. It ended up being a crook tail/brake light connection and bulb. The circuit diagram shows that these 2 circuits are only very distantly and operationly connected, but cleaning up the tail/brake assembly and a new bulb and the front right headlamp worked perfectly again.
Mine was showing similar symptoms - ok high beam and intermittent on low.
heers
A
281368
Reply By: Baz & Pud (Tassie) - Sunday, Jan 13, 2008 at 13:43
dont know much about electrics, but have had a similar problem with a globe in our c/van, got some fine sand paper and gave bottom of globe and the socket a light sand and all was ok.
281369
Reply By: Member - Davoe (Yalgoo) - Sunday, Jan 13, 2008 at 13:51
You do mean the fuse under the bonnet dont you?
not the ones by your right knee
281371
Follow Up By: BayBreeze - Sunday, Jan 13, 2008 at 18:49
Yes the fuses under my bonnet were the ones I was referring too
545768
Reply By: nickb - Sunday, Jan 13, 2008 at 15:47
"It's not the fuse & it probably is not the bulb as it works OK when high beam is turned on."
Most headlights have a low beam filament and high beam filament, and quite common for the low beam filament to fail and the high beam filament remain operational.
281394
Follow Up By: BayBreeze - Sunday, Jan 13, 2008 at 18:48
Cheers I'll replace that bulb as a start
545767
