Rodeo Demister Fan
Submitted: Sunday, Jan 13, 2008 at 18:25
ThreadID: 53447 Views:1950 Replies:4 FollowUps:2
My 1994 Rodeo 4 speed demister fan only switches off and operates on only the highest setting. So I assume the switch is faulty ? Anyone had this problem and was it caused by a faulty switch.
Are there any after market options available ?
How did you go about replacing it, can it be done through the ash tray or what is the best way.
Any advice that you can offer to make the DIY fix less painful would be appreciated
Reply By: mattie - Sunday, Jan 13, 2008 at 18:53
i think there was a problem with water leaking in through a grommet or something like that from the top of the firewall or the base of the wipers, anyway it buggers the fan, on the high setting might be powerful enough to turn the now corroding bearings etc.
MATTIE
AnswerID: 281431
Reply By: Member - Davoe (Yalgoo) - Sunday, Jan 13, 2008 at 19:02
High speed is full 12 volts and the other settings are a lower voltage
common in tojos - the voltage reducer is stuffed
AnswerID: 281433
Reply By: Barnray - Sunday, Jan 13, 2008 at 19:05
There is a thermistor in behind the glove box that acts as a resistor when you use the lower speeds, you find that the coil has burnt out. A bit difficult to remove. Barnray
AnswerID: 281435
Follow Up By: kwk56pt - Sunday, Jan 13, 2008 at 22:48
Ok, thanks for all the information. I dont suppose anyone has any idea on how to go about removing the glove box ?
FollowupID: 545805
Follow Up By: Barnray - Sunday, Jan 13, 2008 at 23:02
Should be a pivot pin in the bottom inside the box with a flat head, use a flat knife blade to lever it out. Mines a 92 model but should be the same. B
FollowupID: 545808
Reply By: donks1 - Sunday, Jan 13, 2008 at 20:52
donks
fan speedresistor gooooooooone
donks
AnswerID: 281456
