Water proof din plug
Submitted: Monday, Jan 14, 2008 at 09:57
ThreadID: 53466 Views:2422 Replies:4 FollowUps:3
Good morning All
I have a tray back slide on with a camera mounted on both tray and slide on camper , I am after a 5 pin din plug for the camera cable so it can be separated when removing slide on from tray. They can be purchased though none of the distributers seem to know where. Any help would be most appreciated. I am situated in the Sydney area
Have a good day Allan
Reply By: Member - Mike DID - Monday, Jan 14, 2008 at 10:20
I would try
Altronics
RS Components
Farnell
If no luck there then convert to 9 pin D Connector as waterproof ones are available from Jaycar.
AnswerID: 281525
Reply By: REV'S - Monday, Jan 14, 2008 at 10:28
I tried Jaycar Wollongong. No Luck
AnswerID: 281529
Follow Up By: Member - Kiwi Kia - Monday, Jan 14, 2008 at 10:45
Did the Jacar people check their catalogue ?
Do a google search on RS and Farnell, mail order electronics catalogues.
FollowupID: 545844
Follow Up By: Member - Mike DID - Tuesday, Jan 15, 2008 at 12:44
It isn't hard to find -
Waterproof 9pin D connector
$13
FollowupID: 546073
Follow Up By: REV'S - Tuesday, Jan 15, 2008 at 19:34
Thanks for the help Mike, when I approached Jacar for a waterproof 4 pin din plug for a reversing camera the salesman said that they did not sell them and i would have to try numerous other stores which i did. They did not tell me i could substitute with anything else, Though i did not ask either.
Thanks again Mike
Regards Allan
FollowupID: 546145
Reply By: Member - Alan H (Narangba QLD - Monday, Jan 14, 2008 at 10:41
rear vision camera
Have you tried Derek? (link above) He is active on this site
AnswerID: 281533
Reply By: Member - Mike DID - Tuesday, Jan 15, 2008 at 12:35
Do you really need a waterproof connector ?
I would just form a loop with the connectors at the top and then cover that in a plastic bag and tie it so the opening remains at the bottom.
AnswerID: 281749
