Troopy Rear Seat
Submitted: Wednesday, Jan 16, 2008 at 20:51
Manic
G'day everyone.
I'm about to find myself in a situation where I need a bit more seating in my troopy. I've got a three seater and would like to put a back
seat in. I've searched the
forum and haven't found anything that relates specifically to this issue and have a couple of questions that hopefully someone can answer. …I'm aware of the issue with the front
seat.
Anyway, I've obviously got to source a
seat from a wreckers which is probably more difficult than is sounds for a Troopy so my first question is does the rear
seat have to be from a 75/78 series or do 80 series cruisers have the same mounting points?
The second question is does the
tank have to be removed to fit the rear
seat or worse, does the gear box need to come out for this operation as
well?
Anyway, I'm interested in anyone's experience regarding this and pointers they may have.
Thanks in advance.
- Manic
Reply By: Wayne (NSW) - Wednesday, Jan 16, 2008 at 21:05
Manic,
When I had the 75 Series it had an aftermarket
seat in the back. It was supplied and fitted by a Van Extras. They do
aftermarket seats for all types of station wagons.
Fitting a
seat in the back is not as simple as buying a bench
seat and putting it in. ADR s, insurance, engineers certificate and
seat belts are a few of the things that have to be dealt with. Also it will change the ADR on the vehicle as it will go from a 3
seat to a 6
seat vehicle. Rego and insurance will be effected.
The
seat can be fitted with out the removal of the tank/ gear box.
I also think that you have to be licenced to fit
aftermarket seats.
Wayne
281990
Follow Up By: Manic - Wednesday, Jan 16, 2008 at 21:45
G'day Wayne
Ideally I'd like to replace the front passenger
seat whilst I'm at it because getting into the back past the existing
seat is a pain. This would make the vehicle a 5 seater which I believe simplifies things with the RTA other than the modificaiton itself.
...and the expense of course but the issue I'm dealing with relates to having a vehicle that's ^completely^ impracticle with kids and I'd like to make it an issue that's maybe a bit difficult instead - I drive a Troopy and they're alway difficult veicles but I'm attached to my vehicle and would rather have it modified than get something more practicle and let's face it, who doesn't like tricking-up their vehicle.
I've found the number for Van Extras so I'll give them a call in the morning.
Thanks Wayne!!!
- Manic
546465
Follow Up By: Members - Bow & Nan - Wednesday, Jan 16, 2008 at 21:55
Manic
I have a Troopy rear
seat in new condition in the Shed if you are interested
546471
Follow Up By: Manic - Wednesday, Jan 16, 2008 at 22:15
G'day Greg.
I'm definitely interested but I'm not a member yet so I can't sent you a PM.
...to be honest on the strength of the response to questions I've put on this site since I bought a 4WD several years ago, that and Wayne's earlier post I just bought a
membership and wheel cover so the
membership is coming soon but as I said, I definitely interested but can’t send you a message.
PS. The image of the RV dragging the van through the bog is absolutely priceless.
- Manic
546479
Follow Up By: Members - Bow & Nan - Thursday, Jan 17, 2008 at 20:27
Hi Manic
You can contact me at gregrmeredith@hotmail.com
546634
Follow Up By: Member - Manic - Thursday, Jan 17, 2008 at 21:16
G'day Greg.
Thanks, I've sent you an email.
- Manic
546644
Reply By: troopyman - Thursday, Jan 17, 2008 at 08:55
An aftremarket bench
seat with retractable
seat belts and a middle lap belt installed and engineer certified at an aftermarket place will set you back about $2000 . Then all you need is a pair of buckets for the front (PITA) . My kids enter by the front passenger side door and climb in between the two buckets which has about an 8 inch gap i guess . Get height adjustable drivers
seat because it is really important . On a low height setting i get a sore back because i am tall and dont have enough leg support . On the higher setting my legs are supported by the
seat and i have excellent viewing over the bonnet . P.S. You need to get the front buckets first so they can weld a little lever on the back to slide the
seat forward from the back to comply or they cannot comply
the bench seat .
282043
Follow Up By: Member - Manic - Thursday, Jan 17, 2008 at 21:20
G'day Troopyman.
Thanks for the advice. It's knowing information like needing the lever on the front
seat now that is going to save some real problems later on and I've got a pretty tired back myself and suffer on long trips so the height adjustable bucket
seat is great advice too.
Thanks again Troopyman.
- Manic
546645
