Aircon
Submitted: Thursday, Jan 17, 2008 at 19:16
Joe
A family member wants to fit an air conditioner to a Jayco Swan Outback.
Any suggestions and recomendations for might work
well seeing this is a camper trailer...models capacity etc,
Joe
Reply By: DIO - Thursday, Jan 17, 2008 at 21:02
Not too sure of the technical in and outs but what about an under-floor unit. Can't think of any suitable location for such an add-on.
282146
Reply By: Notso - Thursday, Jan 17, 2008 at 21:07
There is a Dometic model for Pop Tops, very light around 20 kilos.
Other than that the Heron type that uses up cupboard space which is very limited in that model anyhow
282148
Reply By: Member - Effie C (ACT) - Thursday, Jan 17, 2008 at 21:19
Would be a very interesting excercise working out the heatload to size the unit given that the walls are canvas / plastic. I really think this would be a huge expense for not much gain.
282150
Reply By: sastra - Thursday, Jan 17, 2008 at 23:06
Hi Joe,
We have bought a 3 speed, 12volt, 10 inch fan from USA called Endless Breeze for about $AU130 delivered to
Perth. Couldn't locate same item in Australia.
This is probably the most practical means of cooling in the camper when there is no breeze on those hot and humid days.
It draws approx. 3 amps full speed and 1.5 amps on low which still moves quite an acceptable volume of air.
Ours plugs into a Hella cig. type fused plug which I fitted, connected to 200ah AGM battery bank.
I'm assuming the airconditioning you require is for cooling.
Here's the site where we bought ours. Very easy smooth transaction.
http://www.truckersmall.net/endlessbreeze.html
Good luck
282179
Reply By: DuxLux - Thursday, Jan 17, 2008 at 23:46
I found a good solution on the Jayco
forum -
http://
forum.jayco.com.au/forumMessages.asp?Cat=15&criteria=280&MsgCriteria=26366&Delete=0
Enjoy.
282187
Reply By: Joe - Friday, Jan 18, 2008 at 11:49
Thanks everyone for that feed back.
joe
282253
Follow Up By: Member - JohnR (Vic)&Kath - Friday, Jan 18, 2008 at 13:26
Given the canvas walls mentioned above Joe, a Dometic 1900 that we have in the Karavan can be run off a Honda EU2000i if needed.
546762
Reply By: PradOz - Friday, Jan 18, 2008 at 22:47
hi joe
as i too have a swan i have been interested in the subject for some time.
late last year i seen a similar style camper on ebay for sale that was air conditioned. i even used it as a reply for someone else on here that asked a similar question. search and you may get a glimpse of it.
he actually had fitted a split system in it. the indoor unit was in the cupboard under the front club lounge facing to the rear. the outdorre unit on the a frame. from memory the sliding doors were removed from the cupboard. this would work ok on 240v power set up but not sure on other set ups.
i found that as long as the air was moving around enough you remained somewhat "cool" with these campers and the large window openings it allows for air flow as long as you find a way to move it around. i use several of the square type fans and so far i am ok. not cold, just ok. maybe not at 40 degrees plus though? oh i also make sure i fit an overhead fly from heavy duty silver tarp with a 12 inch gap to the van roof and that really helps. without it i would be stuffed, or maybe cooked?? cheers mick
282395
Follow Up By: PradOz - Friday, Jan 18, 2008 at 22:49
what great spelling hey - i meant outdoor...
546895
