'96 Landrover Discovery Broken Key In Door Lock
Submitted: Monday, Jan 21, 2008 at 20:23
ThreadID: 53753 Views:6503 Replies:7 FollowUps:6
I need some advice for my daughter, she has just broken the key in the door lock of her '96 Landrover Discovery. Not having a spare set of keys, the vehicle is stuck in their local town overnight. She has rung a locksmith and he is saying it could get very expensive, due to having to obtain key codes and immobiliser codes etc etc etc. Has any one been in this situation before ?, What is the best/most economical way to go ?
Thanks in advance.
Neil
Reply By: Louie the fly - Monday, Jan 21, 2008 at 20:51
Can you pick it out with a pair of tweezers? I know someone who had a busted ignition lock in a Disco, about that era. Cost them $800 for a new one. I've a friend thats a locksmith. Nothing he could do for it. But they should be able to cut a key if they can get the blank. Have you tried your local Land Rover dealer with the VIN number?
Good luck. Hope they're not stuck in Wilcannia.
AnswerID: 282972
Follow Up By: res.q.guy - Monday, Jan 21, 2008 at 20:57
Hi Louie
They will try the Landrover dealer in the morning.
They are just looking for the most economic way out.
Luckily they are in the Latrobe Valley area in Vic.
Neil
FollowupID: 547526
Reply By: Andrea11 - Monday, Jan 21, 2008 at 21:00
Hi there,
We have a landrover Disco 97 actually, and I have just found out how really expensive they are to repair, ours is in at the moment to have it's motor reconditioned something to do with a boar sleave, valves and bearings total cost is going to be $4500.00, and I still feel sick just thinking about it all. But as for keys we have a spare that just looks like it has been cut at a standard mister miniute, and it starts the car ok.....Also try joining the following forum for advice (it was really helpfull to me just lately) cause you don't allways have to go to Landrover they are as dear as poison......
Sorry for rambling but hope I have been of some help.
AnswerID: 282976
Follow Up By: Andrea11 - Monday, Jan 21, 2008 at 21:02
See I was rambling the forum address is
www.gclro.com.au
Sorry bout that
FollowupID: 547528
Follow Up By: res.q.guy - Monday, Jan 21, 2008 at 21:10
Hi Andrea
I have passed the info on to her.
Many Thanks
Neil
FollowupID: 547533
Reply By: madfisher - Monday, Jan 21, 2008 at 21:11
Not sure if it will help, but mate of mine uses a ground down hacksaw blade with a tiny little hook on the end to extract broken keys. I have used to extract broken keys from padlocks, should work the same on a car door. If you can extract it you may be able yo get it copied
Cheers Pete
AnswerID: 282978
Reply By: avro - Monday, Jan 21, 2008 at 21:52
There is a MASTER Locksmith at Vermont South Shopping Centre, Burwood Hwy Melbourne that is able to duplicate electronic keys for about $80.00. You will need the broken bit though, or perhaps the whole lock with broken key still in it. Will also need the old electronic bit of the key as he copies the codes from the old and writes them to the new blank. I got one for my Mercedes Sprinter, saved me many hundreds of dollars.
Hope that helps Avro
AnswerID: 282991
Follow Up By: res.q.guy - Monday, Jan 21, 2008 at 22:06
Hi Avro
Will pass it on to her.
Many Thanks
Neil
FollowupID: 547560
Reply By: BMKal - Tuesday, Jan 22, 2008 at 02:11
Hi Neil.
Another forum where you will find plenty of help is Australian Land Rover Owners - www.aulro.com
Not sure exactly on the key configuration for the D1, but for the D2 which I have, your daughter can get a new key from a Land Rover dealership. She will need to provide proof of ownership and the vehicle's VIN number.
Should not need to get anything re-programmed, as you can remove the electronics from the original key fob and install into the new one (may need a locksmith or get the Land Rover dealer to do this). This all assumes that she can get the broken bit out of the door lock, otherwise this lock barrel will also have to be replaced. Any decent locksmith should be able to get the broken bit out of the door lock.
Best of luck .............. BM
AnswerID: 283041
Follow Up By: BMKal - Tuesday, Jan 22, 2008 at 02:14
Just remembered - the D1 key is separate to the remote locking fob. Or at least it was on my last car, a D1. So it should only be a matter of replacing the key. Assume she still has the remote fob - this will still work.
FollowupID: 547617
Reply By: pt_nomad - Tuesday, Jan 22, 2008 at 06:50
Res.q.guy,
We lost a set of Keys for a S1 98 disco and had them replaced.
Cost me about $300, but taht included the donlge for to immobiliser repair.
I purchased the Key blank at land rover and took it to the lock smith. He was able to cut the key from the key number. One of me key sets had a small grey tag with 4 digits on it, these were the numbers used to ID the key. I'd expect Massaro's would be able to chase donw this code for you if you dont have it.
Paul.
AnswerID: 283042
Reply By: Member - Mike DID - Tuesday, Jan 22, 2008 at 08:04
Try Superguing the key stub onto the key bit in the lock - then do a straight pull.
AnswerID: 283053
Follow Up By: Member - Pedro the One (QLD) - Tuesday, Jan 22, 2008 at 16:27
Or even a super strong magnet 'wiggled a tad' might draw it out enough to grab ??
FollowupID: 547732
